F-106
« on: March 30, 2010, 06:30:42 PM » |
Is there any differance in gearing between a tourer and standard? Reason for my question is my ridding budddy's 98 tourer turns 74 mph at 3200 rmp. My 01 standard runs at 65 mph at 3200. All these reading are taken from the stock valk speedo and tac's. Any thoughts?
Disco
Republic of Texas
« Reply #1 on: March 30, 2010, 06:37:45 PM » |
Which rear tires are on the bikes?
2000 Bumblebee "Tourer", 98 Yellow & Cream Tourer, 97 Rescue blower bike 22 CRF450RL, 19 BMW R1250RT 78 CB550K 71 Suzuki MT50 Trailhopper .jpg) VRCC 27,916 IBA 44,783
Valkpilot
What does the data say?
Corinth, Texas
« Reply #2 on: March 30, 2010, 06:46:08 PM » |
And which on the front? Rear will affect tach readings, front will affect speedo. Either (or both) could be influencing the difference.
F-106
« Reply #3 on: March 30, 2010, 07:00:16 PM » |
My 01 has Avon venoms and Verns is running E-3's. Both bike are running stock size tires.
« Reply #4 on: March 30, 2010, 07:13:02 PM » |
I have noted these same differences between my Valk and others that have stock size tires front and rear. It "seems" as if the gearing must be different but I have always assumed that it was in the the mechanicals of the tach and speedo.
« Reply #5 on: March 30, 2010, 07:59:25 PM » |
The gearing is the same, Standard, Tourer, and Interstate. One way to experience this is to ride close together at the same speed and listen for the exhaust sounds to harmonize. It's fun to have four Valks doing this side by side on a four lane highway.
« Reply #6 on: March 30, 2010, 08:09:32 PM » |
So what's with the different engine speeds at the same Mph???
Valkpilot
Corinth, Texas
« Reply #7 on: March 30, 2010, 08:38:42 PM » |
Many possibilities: Differences in actual tire dimensions manufacturer to manufacturer. Differences in wear on the tires Speedometers showing diffenent indicated speeds for the same RPM One way to test the last one is to use a GPS to compare actual speed to indicated speed. Metric bikes are notoriously incorrect. Mine consistently indicates about 10% faster than I am actually going.
lee
« Reply #8 on: March 31, 2010, 07:02:35 AM » |
womp womp womp womp womp womp womp womp womp womp: big difference in engine RPM womp womp womp womp: getting closer in engine RPM wooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo same engine RPM now look at speedo and tack. Is that what you meant Gryphon Rider?
Time is not what is taken but what remains. C. Drewry
« Reply #9 on: March 31, 2010, 02:24:14 PM » |
womp womp womp womp womp womp womp womp womp womp: big difference in engine RPM womp womp womp womp: getting closer in engine RPM wooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo same engine RPM now look at speedo and tack. Is that what you meant Gryphon Rider?  Yeah, that's what I meant. I just don't have the technical vocabulary to describe it as precisely as you did.
« Reply #10 on: March 31, 2010, 06:11:32 PM » |
Trigger wheels??
tlanz
« Reply #11 on: April 01, 2010, 10:20:32 AM » |
