January 30, 2026, 03:47:53 PM
Direct Airflow Meter
Topic: Direct Airflow Meter (Read 1946 times)
Dag
Country Rep. Norway
March 31, 2010, 02:40:53 AM »
A option for carb sync is a direct airflow meter like the STE Flowmeter which measures the actual airflow though carbs or F.I. throttle bodies. I think this must be the most accurate and easiest to use tool of the bunch, as no vacuum connection is needed.
Does anyone here have any experience with this tool?
http://www.cbperformance.com/catalog.asp?ProductID=572
fstsix
Re: Direct Airflow Meter
March 31, 2010, 05:33:03 AM »
I had duel Webers on one of my VW Sandrails it worked good, but the Carbs were easy access, and only 2 downdrafts to balance, it would be a lot of work to try to balance 6 carbs on the Valk considering we would have to remove the air cleaner, but it did work good.
March 31, 2010, 08:01:03 PM »
This is the best out there, there is only one other tool to balance the carbs like this and it cuts off the air flow so you never get a accurate adjustment. This lets the air through and there's no adjustment needed to work and it works on the most verity of applications out there. I have never needed any other adapters to make it work and even a rag over the opening in some case allowed me to make a good adjustment on the carbs. sometimes the openings are not round or odd shaped and this still worked. I dont know what other info you need. OH How about this it worked with 6 2 barrel carbs with no problem.
