January 30, 2026, 03:47:36 PM *
Author Topic: I "feel" a clunk when i drop the throttel at low speed...  (Read 2302 times)
Bonzo
« on: April 02, 2010, 04:11:28 AM »
I am thinking U-Joint, but there is no vibration, heard or felt. '97 standard, 64,000 miles
Woops, I'm sorry.
Algonquin Highlands, Ontario Canada
« Reply #1 on: April 02, 2010, 04:17:29 AM »
When is the last time you checked the dampers in the rear wheel, maybe they are worn enough to create slack.
DFragn
« Reply #2 on: April 02, 2010, 04:19:13 AM »
I would inspect the U-Joint, all rear drive splines and rear wheel dampeners.
Warlock
Magnolia, Ms
« Reply #3 on: April 02, 2010, 06:49:35 AM »
Last time did that it ended up being the pinion joint and drive shaft. But all other mentioned could be the problem.
David
Bonzo
« Reply #4 on: April 02, 2010, 08:09:12 AM »
Well I  guess it's time to pull the rear wheel! I might as well order a new Cooper Zeon while I am at it! Thanks!!!
Woops, I'm sorry.
« Reply #5 on: April 02, 2010, 06:05:45 PM »
Let me know if you want me to come up and be useless Steve
I guess your eyes are all better now?
Bonzo
« Reply #6 on: April 03, 2010, 06:55:25 AM »
i can see out of the left eye, but it is still askew, no parallel line vertical or horizontal and distance is real screwy. Like the early '70 !
Woops, I'm sorry.
