January 30, 2026, 04:44:53 PM *
Author Topic: Horn Relay?  (Read 3046 times)
Fritz
Manitowoc, Wis.
« on: April 02, 2010, 05:40:43 PM »
 I want to put a different horn on the bike. I'm going to try a cheap auto horn, but I've been reading hear about having to use a relay. Where do I get one? Are there different kinds. I know no nothing about a these relays.
Thanks in advance
Thunderbolt
Worthington Springs FL.
« Reply #1 on: April 02, 2010, 05:48:45 PM »
Here is a link   http://www.rattlebars.com/mtz/hornrelay.html
X Ring
VRCC #27389, VRCCDS #204
« Reply #2 on: April 02, 2010, 08:10:32 PM »
Fritz, run the positive and ground wires back to the relay to trigger it. Then run a fused wire (or a wire from a fused source) to the relay and a wire to the new horn.  It's not hard actually it's pretty easy.  Follow the instructions on Rattlebars page to connect to the relay.
Fritz, you can do this.  We're here for you.
Marty
JimC
SE Wisconsin
« Reply #3 on: April 02, 2010, 08:38:37 PM »
Fritz,
I can help you out with that.
Give me a call to set up a day, I have several relays in my shop that we can use.
262-fourfourone-0333
Jim
Jim Callaghan    SE Wisconsin
« Reply #4 on: April 02, 2010, 09:48:43 PM »
Radio Shack has 12 Volt relays. Available in 30 amp or 40 amp. $5-$6. It sounds like JIMC is going to help you.
Larry
Northeastern BC, Canada
« Reply #5 on: April 02, 2010, 11:05:50 PM »
Don't those cheap auto horns work the same as the cheap motorcycle horn on the Valk? Just connect the same wires that go to the stock horn to the auto horn, unless I misunderstaood and you are putting on an additional horn?  ???
Thunderbolt
« Reply #6 on: April 03, 2010, 04:49:24 AM »
if it draws or pulls too much current or amperage, it will  blow the fuse.  That is the reason for the relay.  It's actuated by a low current, but will transfer 30 or 40 amps to the device that it is powering.
Fritz
Manitowoc, Wis.
« Reply #7 on: April 03, 2010, 05:35:10 AM »
Thanks for the offer Jim. But after reading all the info on Chet's site I can handel is project myself.
Thanks again for everyones help
Fritz
BradValk48237
Oak Park, MI
« Reply #8 on: April 03, 2010, 09:31:05 AM »
Has anyone used dual tone car horns before?...   I have an I/S and thought I could mount one in each radiator cover/pod... Use the same relay to power both?
I don't know if I'd want a Stebel...... Don't want to scare the crap outta my co-riders every time I want to get their attention!
B
« Reply #9 on: April 03, 2010, 09:37:29 AM »
There are those who have a stebel in each pod.   cooldude  hoser
scoot
Lifes too short Ride it hard
Grand Rapids Mi.
« Reply #10 on: April 03, 2010, 06:16:42 PM »
I went to the junk yard (auto recyclers now) and got a set of horns off a cadilac. I used one relay and mounted them under the bike in the swing arm area. They have have that great sound, it's funny to see people look around to see who is honking at them. I think between the cost of the horns and the relay I may have $15.00 into the who thing. The reason for the relay is so you don't burn the switch out.
Beernuts
« Reply #11 on: April 04, 2010, 04:49:30 AM »
I put these on my bike and sound great did the swing arm mount.  Horns are small but loud http://www.motoshop.net/mm5/merchant.mvc?Screen=PROD&Product_Code=MAM14&Store_Code=AIM&search=horns&filter_cat=&PowerSearch_Begin_Only=&sort=&range_low=&range_high=
RoboCop
Rose City OREGON
« Reply #12 on: April 04, 2010, 11:26:05 AM »
Aerostich horn and relay, $21.  I've got one on my Valk, can make a sound file if you wanna hear it toot.
http://www.aerostich.com/a-to-b-utilities/horns/fiamm-freeway-blaster-horn.html
« Reply #13 on: April 04, 2010, 12:06:45 PM »
Should a relay be used for any non oem horn? I gotta HD horn that works some of the time. Sounds like not enough ummf for it to work.
RoboCop
Rose City OREGON
« Reply #14 on: April 04, 2010, 12:58:22 PM »
Should a relay be used for any non oem horn? .
Only if the new horn's power draw exceeds the the rating of the stock wiring.  A little info on relays here:
http://www.rowand.net/Shop/Tech/AllAboutRelays.htm
Larry
« Reply #15 on: April 04, 2010, 01:55:32 PM »
Only if the new horn's power draw exceeds the the rating of the stock wiring. ...
So, how how much is the power draw rating of of our Valks horn wiring? I can't imagine a regular horn or two would draw that much more compared to our stock horn, unless you are hooking up several together or maybe hooking up a Nautilus or two. No sense making a whole bunch of extra work for yourself if there is no need, piece of mind if you don't know is worth something too. Just another 3c worth.  Smiley
« Reply #16 on: April 04, 2010, 02:10:17 PM »
Thanks in advance
I use dual dodge truck horns, very, very loud. $5 parts yard and two boat horns under the swing arm. I use a relay.
