June 16, 2025, 11:26:10 PM
fuel consumption
Topic: fuel consumption (Read 3509 times)
boubou
maniwaki,québec,canada
fuel consumption
March 12, 2009, 04:43:17 PM »
My friend in Thailand got problem with is valk.What can cause big fuel consuption, he said that he take 2.5 gal.for 60 mil. at a speed of 60mph. My 2000 i/s is much better then that.Thank you. Boubou vrcc 15101
p.s. sorry for my bad english writing
Big Tom 10628
Surprise AZ.
Re: fuel consumption
March 12, 2009, 04:49:18 PM »
Depending on how these bikes are ridden they can be very thirsty.. I have gotten as low as 17 MPG with my 1999 IS.
1999 Valkyrie Interstate
2006 Gold Wing
Garland
#618
Hendersonville NC
March 12, 2009, 05:03:58 PM »
My fuel consumption seems to have gone up with the addition of ethanol in the last few years. My 99 tourer used to hit reserve at 125-135 and now it is 110-120. Don't know if Thailand is going the same way with additives.
John U.
Southern Delaware
March 12, 2009, 06:37:16 PM »
Your friend should check /replace his air filter. Also check for vacume leaks in the tubes and tighten the clamps on the rubber connecting boots. I would check the condition of the plugs, one of them may be misfiring. Some carb/fuel system cleaner in the gas will help clean gunk that may be affecting the carburators. Ethanol will reduce gas mileage, it will also gum up the carbs.
Good luck
=> InZane XXV
