December 28, 2025, 01:51:31 AM *
Author Topic: Rotella T5, T6  (Read 7812 times)
Big Rig
Woolwich NJ
« on: April 05, 2010, 04:54:03 AM »
For those that use it, what is the difference? I do not remember Rotella labeling T5 or T6...
Warlock
Magnolia, Ms
« Reply #1 on: April 05, 2010, 06:27:02 AM »
The 5w40 in the blue and the 15w40 in the white are good to use. The new one which is a blend in the Grey bottle doesn't carry the right codes for motorcycles.
David
Big Rig
Woolwich NJ
« Reply #2 on: April 05, 2010, 10:53:24 AM »
ok, so I will return the T5,
what are the codes i should be looking for?
Oyeaa
« Reply #3 on: April 05, 2010, 04:41:09 PM »
I am not an oil expert but...
I use rotella T6
From their web site.
Do you recommend using ROTELLA in wet clutch applications?
ROTELLA T does not contain friction modifiers that are added to many passenger-car-only-oils, and it does not comply with all requirements of ILSAC GF-1, GF-2, GF-3 and GF-4 (the ILSAC oil specifications are often recommended by many gasoline passenger car engine manufacturers). That can be good for motorcycle/ATV use. Friction modifiers can upset wet clutch operation. And the ILSAC requirements limit phosphorus content.
Shell Rotella T5 Synthetic Blend Technology. The combination of synthetic blend base oils.
Shell Rotella® T6 Full Synthetic
http://www.shellusserver.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=310&page=28
http://en.wikipedia.org/wiki/Shell_Rotella_T
sugerbear
wentzville mo
« Reply #4 on: April 05, 2010, 05:47:31 PM »
couldn't find my mobil 1 today so bought the t6, just changed.  we'll see. Smiley Smiley
Warlock
Magnolia, Ms
« Reply #5 on: April 05, 2010, 05:54:23 PM »
JASO-DH-2 is the code you need to look for. This is a code that Japan uses for their approved oils. The T5 has it in the 10w30 weight, but not in the 10w40. The T3 has it and so does the Rotella 15w40 in the white jug. Up-date, just looked at the site and the T5 has it listed in the 15w40 now. They didn't carry the code a few months ago. My bad. Looks like all the Rotella oils are good. I have been using the T6, but next oil change switching to the 15w40 in the Rotella triple protection.
David
« Last Edit: April 05, 2010, 06:08:32 PM by Warlock » Logged
Big Rig
Woolwich NJ
« Reply #6 on: April 06, 2010, 05:08:16 AM »
So, use it? or return it?  Shocked Shocked
That is the question.... Wink
Warlock
Magnolia, Ms
« Reply #7 on: April 06, 2010, 06:28:59 AM »
I've used the T6 for a while. The only reason I'm switching is having a hard time finding the T6. The T6 is a good oil. I guess I could order it.
David
Farther
Quimper Peninsula, WA
« Reply #8 on: August 22, 2010, 02:51:22 PM »
Just went for a 127 mile ride with the first time on Rotella T6 after using Amsoil motorcycle and Mobil 1 motorcycle specific oil.  I also went with a Hondaline auto filter.  Other than more gear whine I noticed no difference.  The gear whine was annoying..... I may go back to Mobil 1 motorcycle oil or try the Mobil 1 truck oil next time.  Anybody have a report on the gear whine with the Mobil 1 truck oil?
« Last Edit: August 22, 2010, 03:48:42 PM by Farther » Logged
~Farther
sugerbear
wentzville mo
« Reply #9 on: August 22, 2010, 03:14:04 PM »
i ran the t-6 for a few days, whine got to me changed back to mobil 1 20-50
« Reply #10 on: August 22, 2010, 04:38:45 PM »
I ran the mobile 1 in the truck high milage oil. Hated it. Went with rotella since then. Less gear whin with the Rotella.  ???
Spirited-6
Nicholasville, Ky.
« Reply #11 on: August 23, 2010, 08:28:27 AM »
The only thing and I mean the ONLY thing I can fault the Valk. for is GEAR WHINE. If oil would make it a little less "whiney" I would jump on it. I guess it depends on who is using what and how good thier ears are. I have used Rotella for about ten years but would change in a New York Minute if I thought another oil would HELP. "Opinions" I guess it`s like belly buttoms, everyone has one.  Undecided
I guess you need to try and see !!!
Spirited-6
« Reply #12 on: August 23, 2010, 08:45:14 AM »
My $.02.  I think it has more to do with the weight of oil you are using.  Less noise with the 20w-50w Mobil-1 than the 10w-40w Rosmella.  Here in TX, we don't need the winter 5w or 10w oils on that end of the spectrum.
YMMV.
Hay Cool
Red Diamond
Beaumont, Texas
« Reply #13 on: August 23, 2010, 05:31:50 PM »
YMMV.
Hay Cool
Want to get rid of gear whine and whining about oil period, follow HayHauler's advice.
