January 30, 2026, 08:12:31 PM *
Author Topic: Tire change  (Read 4694 times)
piper51
VRCC31055 VRCCDS0227
Ohio
« on: April 05, 2010, 04:01:38 PM »
Anyone here changed their own tires? Hate to pay 25 a tire to change them. Just cheap.
« Reply #1 on: April 05, 2010, 04:25:02 PM »
Yup!
Change and balance!
Not something for beginners tho!
roboto65
Conroe,TX
« Reply #2 on: April 05, 2010, 04:33:16 PM »
Do my own also couple of tire irons and a few tricks and you too can change your own !!! cooldude
Allen Rugg
VRCC #30806
1978 Kawasaki KZ 650 project
asfltdncr
« Reply #3 on: April 05, 2010, 04:59:02 PM »
There is a homemade bead breaker in the forum somewhere with pics.
Then it's all about the lube, rim savers, and mount/demount bar available from NOMAR.
Go darkside and put a rear tire up front and you won't be worrying about it for quite a while.
Bob E.
Canonsburg, PA
« Reply #4 on: April 06, 2010, 11:07:20 AM »
I bought the Harbor Freight tire changer and it has more than paid for itself several times over. cooldude
Farther
Quimper Peninsula, WA
« Reply #5 on: April 06, 2010, 01:42:03 PM »
...put a rear tire up front and you won't be worrying about it for quite a while.
  What size and brand do you use?
~Farther
RoboCop
Rose City OREGON
« Reply #6 on: April 06, 2010, 09:55:58 PM »
Use this homemade stuff to do all my tires, along with a couple of old school tire irons. Doing it on a warm day helps, diverse cursing vocabulary is mandatory.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #7 on: April 07, 2010, 05:03:13 AM »
Local tire shop (cars and trucks) changes mine for $5 a wheel when I bring them in to him. I use Dyna Beads to balance. For that much, I won't break out the tire irons.
tlanz
« Reply #8 on: April 07, 2010, 05:23:38 AM »
cooldude +1 on the Harbor Freight tire changer; My buddy has one, so I sprung for the Marc Parnes balancer http://www.marcparnes.com (no affiliation) and have never looked back.
asfltdncr
« Reply #9 on: April 07, 2010, 10:55:42 AM »
Dunlop d404 up front and goodyear triple assurance (205/55/16) in rear.If you don't want to risk or mess with clearances, I recently heard of a forum member that used a 195/65/16.The larger diameter(65) will drop your rpms and I don't think you would have to do any fender nut modifications as you would on the 205.
1FAST6
Sanford, NC
« Reply #10 on: April 07, 2010, 12:01:39 PM »
I've been using my Harbor Freight changer for several years now.  Takes a few times to get the knack, but now I do them with no problem.  Just did F&R took less than 1 hr total.  I also use (and re-use) Dyna Beads.  I think they've been in 4 rears and 2 fronts so far...
« Reply #11 on: April 07, 2010, 12:06:09 PM »
Bob E.
Canonsburg, PA
« Reply #12 on: April 07, 2010, 02:10:40 PM »
I broke a 2x4 with a rig similar to that (yes it was vertical, but buckled)...throwing my back out in the process.  That SUCKED!!!  The bead breaker on the HF changer is much more gooder.  Cheesy
« Reply #13 on: April 07, 2010, 04:20:32 PM »
Every time I change a tire I think to myself, "self, you should get one of those HF tire changers",
but I don't have a floor to bolt it to... my 2X4 almost breaks every time...
Spirited-6
Nicholasville, Ky.
« Reply #14 on: April 08, 2010, 07:49:55 AM »
BOY, talk about "BARE BONES"   Evil
I tend to like stuff like this.  Roll Eyes
Spirited-6
asfltdncr
« Reply #15 on: April 08, 2010, 08:22:11 AM »
I do have a HF changer but if you wnt to make it easier on yourself and the wheel,buy the NO-MAR mount/demount tool(it has teflon work surfaces)for about $100 and their lubricant.
It's pretty easy to balance your tires as well.HF sells one of those for cheap and you can buy the stick on weights almost anywhere.
« Reply #16 on: April 08, 2010, 08:43:27 AM »
I once tried bucket balancing using the wheel's bearings... not so hot... now I bucket balance with Marc Parnes (tm)...  cooldude
I also have a gallon of this stuff, a disgusting product if you have to google for it:
KY,Dave (AKA Misunderstood)
Specimen #30838 DS #0233
Williamsburg, KY
« Reply #17 on: April 08, 2010, 10:02:54 AM »
 2funny 2funny 2funny
Mildew
Live, Not Just Exist
Auburn, Ga
« Reply #18 on: April 08, 2010, 11:04:57 AM »
I bought the harbor freight thing and it's a dust collector. I still couldn't get my tire off. I went to a motorcycle shop and he did it for free. Lol.. About bringing the rpms down. I ride to work every day running about 3700 rpm. That's 80 mph with a 205/60. What difference would a 65 make. I read some time ago that someone uses a 70. I know the big harleys with the extra gear run a pinch under 80 at 3000 rpms. That's where i'd like to be without buying a harley. Lol
« Reply #19 on: April 08, 2010, 11:34:10 AM »
Sell cheap?  Smiley
-Mike "they're already pretty cheap, and I don't have a floor to bolt it to..."
Sodbuster
« Reply #20 on: April 10, 2010, 06:11:44 AM »
Got any dimensions on that bead breaker ??  How long is that handle ??
VRCC # 30938
John U.
Southern Delaware
« Reply #21 on: April 10, 2010, 07:31:35 PM »
I've found that the Harbor Freight bead breaker (the separate tool, but nylon cutting board pieces can be screwed on to protect rims) works well. If you're going to get the HF tire changer get  the No-Mar tire change bar and these to protect your rims: http://www.nomar-secure.com/product_p/ac-rc-spools-tall.htm
They sell two versions, get the tall ones for larger rims.
RoboCop
Rose City OREGON
« Reply #22 on: April 10, 2010, 10:18:10 PM »
It's currently stowed behind a big pile of crap, can't get a tape on anything but the handle and it is 5 ft long, I should have gone at least 6 ft.  Only other things that really matter is to make it deep enough to not bottom out on the rotor and make it wider than the rotor  but narrower than the rim.
Farther
« Reply #23 on: April 11, 2010, 09:52:27 AM »
Hey RoboCop: Is that Mount McLoughlin in your signiture photo?
~Farther
RoboCop
Rose City OREGON
« Reply #24 on: April 11, 2010, 04:12:23 PM »
Other end of the state, Mt. Hood just east of Portland.  Pics taken near Hood River.
1FAST6
Sanford, NC
« Reply #25 on: April 12, 2010, 11:47:57 AM »
My HF Tire Changer is not bolted to the floor.  I bolted it to an old piece of plywood so I can move it around.  Maybe 3' square.  I stand on it when using the changer and I have no troubles at all, then shove it in the corner to store till next time.
« Reply #26 on: April 12, 2010, 12:08:34 PM »
Hmmm... I wondered if the plywood trick might work... I probably age about a year or two every time I change a
Valkyrie tire with my current tools - 10 or 11 inches long:
If I get a HF changer and bolt it to some plywood, then all I'll need is a corner!  cooldude
maniscar
VRCC #2225
Southern NH
« Reply #27 on: April 13, 2010, 09:03:10 AM »
That's what I do too.  I use a 4' x 4' x 3/4" piece of plywood.  I mount the HF slightly off center for more standing room.  Works great!
  Rich
2003 Valkyrie Standard
1FAST6
Sanford, NC
« Reply #28 on: April 13, 2010, 09:57:44 AM »
You'll still need those tools!  I use the bar on the changer to get it about 80% on, then use the spoons to pop it the rest of the way.  After doing about 20 or so tires (MC and DS) I decided it's much easier to use that combination.  First bead usually goes on no problem.  For the 2nd, I use 1 spoon to hold the bead from slipping out while you run the tool around as far as she wants to go, then prop the bar up on the changer to hold the bead in place, slip the 2nd spoon in just behind the first one and pry it on.  Pull the 1st spoon out, slip it in between the bar and the 2nd spoon, pry it on and you're done.  If you use Dyna Beads, put them in after you do the first bead and before the 2nd.
« Reply #29 on: April 13, 2010, 10:16:12 AM »
Heck, with a generous application of rubber lubricant, I can get it 70 (maybe not 80)  percent on with no tools...
of course, watching me mount a tire is probably a lot like watching sausage being made... and you don't want me
or my little spoons anywhere near your shiney/unscratched/chromed wheels  coolsmiley
The hardest part, for me, is getting the second bead of the old tire off, that seems like the place
where a real tire changer would help...
1FAST6
Sanford, NC
« Reply #30 on: April 14, 2010, 06:46:22 AM »
Taking them off is a breeze!  1st bead on is no trouble either.  I have to work at the second bead on, but like I said, after a few times it gets easier.  First few times I had me and two other guys trying to force it on.  As with most things in life, "It's easy when you know how!"
