January 30, 2026, 09:31:21 PM *
Author Topic: rear wheel drive flange  (Read 2123 times)
Darren
Lees Summit, Missouri
« on: April 06, 2010, 05:10:12 AM »
Is there  rear wheel drive flange the same for all years and model Valkyries. Have worn splines and need to replace.
Darren
MP
North Dakota
« Reply #1 on: April 06, 2010, 05:11:18 AM »
Yes.
"Ridin' with Cycho"
Daniel Meyer
The State of confusion.
« Reply #2 on: April 06, 2010, 05:36:49 AM »
It is the same, but note...if the flange is worn, the female part in the rear pumpkin is equally worn...so you need to replace the pinion set or find a good used rear drive.
CUAgain,
Daniel Meyer
Darren
« Reply #3 on: April 06, 2010, 07:11:09 PM »
Well crud. I didn't think about having to replace the part in the pumpkin. I am sure this has been asked and answered a thousand times but how expensive is it and how difficult a job is it?
john
tyler texas
« Reply #4 on: April 06, 2010, 07:18:53 PM »
HONDA GOLDWING VALKYRIE GL1500 1500 FINAL WHEEL FLANGE   HONDA GOLDWING VALKYRIE GL1500 1500 FINAL WHEEL FLANGE   Buy It Now or Best Offer   $65.00   21d 19h 47m
vrcc # 19002
tlanz
« Reply #5 on: April 07, 2010, 04:20:08 AM »
Before you go off & purchase a new 'pumpkin' or parts for it, PLEASE inspect the the splines inside the ring gear. The ring gear is a hardened component; as such it 'should be' harder than the drive flange and should NOT experience the same wear as the flange (sorry Daniel). That's not to say the ring gear isn't worn, however, particularly if the drive flange is excessively worn. Just inspect it carefully before you start throwing $$$$ around.
Daniel Meyer
« Reply #6 on: April 07, 2010, 08:13:32 AM »
No apology needed. Obviously you should make sure you need a part before you replace it...but..
I've never seen a valk or a wing with a worn wheel flange that the mate in the pumpkin also wasn't shot. Not one.
If the wheel splines were worn, their mate was equally worn.
I suspect those splines are NOT harder than the wheel flange...the ring-gear sure, but the spline component is pressed into it and so could be different metal.
Anyway, check it out.
I think your best bet cost-wise is to pick up a used but good pumpkin on ebay or pinwall etc. They generally go for far less than the parts to repair in.
Be careful when you put it back together. These parts should not normally wear appreciably (mine are 130k+ miles with no visible wear)...it's order of assembly and/or bad bearings that tear 'em up. Hint...tighten the 4 nuts that hold the pumpkin to the swing arm AFTER the axle has been torqued. This is the single most important step in rear wheel replacement.
CUAgain,
Daniel Meyer
« Reply #7 on: April 07, 2010, 08:29:32 AM »
When I wore out the pinion end of my drive shaft and replaced the shaft, I replaced the pinion cup at the same time,
but I wonder if I needed to...
"better safe than sorry" and "a penny saved is a penny earned" are at odds sometimes...
