January 30, 2026, 09:30:25 PM *
Author Topic: Drive Shaft difference between 1997 and 1998 up  (Read 3135 times)
Crazyhorse
Hattiesburg, MS
« on: April 07, 2010, 12:29:46 PM »
Can someone tell me the difference between the drive shafts for the 1997 Valks and those 1998 and after? I had a shaft (from my 97 standard) loose some teeth (off the end were the retaining ring goes) and replaced it with a new shaft I had for my 99 I/S. Went to order a new shaft and found a different part # and price for the 97 verses the 98 standard or 99 I/S. It seem to fit the pinion cup and the yoke find. I haven't ran the bike and would like a response before I do.
Mac
KY,Dave (AKA Misunderstood)
Specimen #30838 DS #0233
Williamsburg, KY
« Reply #1 on: April 07, 2010, 01:54:11 PM »
I was under the impression that they were all the same size. They may have different part #'s and still be the same.Also I replaced one that had some teeth missing where you refer and they aren't all needed. They only hold the ring in place so you don't need them all. NowmI have a spare OR 2.
« Last Edit: April 07, 2010, 04:40:53 PM by Misunderstood » Logged
Daniel Meyer
The State of confusion.
« Reply #2 on: April 07, 2010, 03:38:16 PM »
They are...to the limits of my ability to measure them...identical.
CUAgain,
Daniel Meyer
Williamsburg, KY
« Reply #3 on: April 07, 2010, 04:41:31 PM »
I was under the impression that they were all the same size. They may have different part #'s and 'T NEEDED. tHEY ONLY HOLD THE RING IN PLACE SO YOU DON'T NEED THEM ALL. nOW i HAVE A SPARE OR 2. still be the same. Also I replaced one that had some teeth missing where you refer and they aren:
I think MISUNDERSTOOD meant to type this:
I was under the impression that they were all the same size. They may have different part #'s and still be the same. Also I replaced one that had some teeth missing where you refer and they aren't needed they only hold the ring in place so you don't need them all.  Now I have a spare or 2.
--- but then again I may have misunderstood his message.
Fixed. Thanks, Dave
upjeeper
« Reply #4 on: April 07, 2010, 07:07:50 PM »
shafts for a 97 model year are $100
for a 2000 model year they're $45
other then that, i do not know the difference
Crazyhorse
Hattiesburg, MS
« Reply #5 on: April 08, 2010, 05:50:54 AM »
I checked the bad 97 shaft with and old shaft out of my 99 I/S and can't tell any difference. The only noticable defference is in the price as mention above and the part #.
I ordered two more shafts from directparts. The less expenses ones of course. I'm going to run the one I put is the bike and see how it does. Greenzila is back in action.
The old shaft had to much missing to reuse though it was not worn much at 39K.
Ferris Leets
Catskill Mountains, N.Y.
« Reply #6 on: April 08, 2010, 06:01:18 AM »
I REALLY like that paint scheme.  What are the names of those colors?
I would not copy yours but I would like to do something similar to the my G&G Nomad on the '99 IS.
Crazyhorse
Hattiesburg, MS
« Reply #7 on: April 08, 2010, 08:34:48 AM »
I got the bike a few months ago from a member down in Fla.
The bike had been setting for a while and I have been busy bringing her back to life. I know nothing about the colors. Sorry.
Mac
Jeff K
« Reply #8 on: April 08, 2010, 01:49:13 PM »
Mac
Wayne's World in Jacksonville did the paint job. I'm sure he could tell you.
junior
new hampshire
« Reply #9 on: April 09, 2010, 12:04:28 AM »
the differance between the 2 shafts are the tinsel strength, cause the 97's has more horse power
Williamsburg, KY
« Reply #10 on: April 09, 2010, 09:15:39 AM »
That's true, 97 BLACK Tourers had the most torque and required the extra strength in the shaft. I like that !  cooldude
Madmike
Campbell River BC, Canada
« Reply #11 on: April 09, 2010, 10:00:14 AM »
Nope - "tinsel strength" is how many Christmas trees they can drag......
Dan Manko
« Reply #12 on: April 09, 2010, 12:59:43 PM »
Thanks for the information. I had asked this same question a year and a half or two years ago and did not recieve a single reply. NOW I'll know to buy the lower priced one next time.
