January 30, 2026, 09:30:30 PM *
Author Topic: Self talk lessons are the best  (Read 2178 times)
Warlock
Magnolia, Ms
« on: April 07, 2010, 06:51:28 PM »
Converted my left rear bearing to the same size as the right rear. Ordered 2 3204 bearing from McMasrer Carr. Received them for both bikes. Anyway installed one on my Tourer. Was riding and was hearing a popping sound last time home. Took the rear end back off and installed new dampeners. Ok problem solved I thought. While riding Sunday popping came back and really can hear it better on left hand turns. I ordered 2 new SKF 3204 American made bearings and replaced both sides. Once I got the one off from McMaster I decided to pull one of the shields off hoping this could be the problem. Well the 8 ball bearings on each side is support by plastic. I couldn't believe this. Pulled the other side and same thing. I could not believe these heavy duty bearing with plastic to keep the bearing apart from each other. I feel I have solved the popping in the rear end. My so call saving money cost me in the long run. These bearing came from Usolivia (sp). From now on US bearing and I thought McMaster would sell a good bearing. That's what I get for thinking again.
David
X Ring
VRCC #27389, VRCCDS #204
« Reply #1 on: April 07, 2010, 10:21:33 PM »
The next time you get to thinkin like that, call me.  I'll ride over and smack you in the back of the dman head.   uglystupid2  Now you know why I spent a c-note for my bearings.
Marty
Jack
Benton, Arkansas
« Reply #2 on: April 08, 2010, 06:55:58 AM »
Dave, I put oem bearings back in mine.  OEM may not be the best bearing out there but it removes the quesswork out of buying.  I keep an extra set in my toolbox for next time.
btw, you gotta get up here to visit sometime.  Cool
PAVALKER
Pittsburgh, Pa
« Reply #3 on: April 08, 2010, 08:43:59 AM »
Marty
What    Shocked  ?    Did that include installation?     Seriously, what brand of bearings did you get that you had to spend on C-Note on?
John
X Ring
« Reply #4 on: April 08, 2010, 09:18:23 AM »
SKF 3204-2RS with shipping and tax came to $48 each.  Buying OEM NSKs from the stealer would have been $20-25 more expensive and getting them from HDL would have been about the same but would have taken a lot longer to get here.
Marty
« Last Edit: April 08, 2010, 09:35:34 AM by X Ring » Logged
X Ring
« Reply #5 on: April 08, 2010, 09:26:45 AM »
Actually the NSK bearings that Honda uses are top tier bearings.
Marty
« Reply #6 on: April 08, 2010, 04:17:20 PM »
Marty
Thats what I find around here. Was going to do the double row but will do it later. Another quote on a bearing was $80.
Warlock
Magnolia, Ms
« Reply #7 on: April 08, 2010, 04:25:28 PM »
Marty
Well to get my overnight I payed $132.00 for 2. Then got on the phone with McMaster and they are giving my money back on the bad bearings. So all went well so far.
David
Warlock
Magnolia, Ms
« Reply #8 on: April 08, 2010, 04:28:02 PM »
Kathy and I was just talking about making a trip up there to ride some roadies. Will get with you later. Hoping to get several couples to ride up there.
David
