January 30, 2026, 08:12:39 PM *
Author Topic: Rear wheel cleaning  (Read 2891 times)
jriling3
« on: April 11, 2010, 09:26:47 AM »
Okay I give up. Rear tire still on bike. Right side cleaned up okay but the left is pitted with black spots bad. Tried 2500 wet/dry, 1500 same, and now do I go to 1000? Did the mini ball with the polish with the jeweler's rouge. Do I just give up because no one will see that side because of the bags. I can't take off the wheel do to a time limit. All the tins have to be back on by wednesday to go back to the painter for graphics refit on the trunk. Thanks in advance for any help. John VRCC#9214
Joe Hummer
Arnold, MO
« Reply #1 on: April 11, 2010, 09:42:44 AM »
Hey John,
I used some steel wool on mine to take care of most of the crude.  I haven't put a mirror finish on mine...just try to keep them clean(er) looking.
It is definitely easier to do this with the wheel off the bike...but you can still do it with the bike on a lift.
Joe
1999 Valkyrie Interstate
JimC
SE Wisconsin
« Reply #2 on: April 11, 2010, 07:11:58 PM »
JR
If you did your wheel in the order you posted, you did it backword. You should use the heavier sand paper first.
I just did mine and started with 400, then went to 600, then to 1000, then 1500, then I hand polished them with Meguires billet polish, turned out well. But it is a pain in the hand, my wrists and fingers ached for a week after doing it.
JIm
Jim Callaghan    SE Wisconsin
Red Diamond
Beaumont, Texas
« Reply #3 on: April 11, 2010, 07:23:23 PM »
I used a method from another post suggested for me, fine steel wool or copper wool with WD-40. Use medium to start with if you want to, but the fine wool works great. The wool leaves no scratches, just polish or wax finish.
PAVALKER
Pittsburgh, Pa
« Reply #4 on: April 11, 2010, 07:54:40 PM »
Kitchen scrub sponge with Soft Scrub w/bleach to clean em off.  Brillo to clean it a little more, and smooth it up then hose it off wipe it down and finally Mothers Mini Power Ball with polish (I prefer White Diamond).  Wheels can stay on the bike, the Mini Power Ball will fit behind the rotor and such.  Once you clean em off and polish em up good, you can do it by hand to touch up as needed.  Put a coat of wax on em so you can hose em when you wash the bike to help keep them looking that way.
« Last Edit: April 11, 2010, 07:56:31 PM by PAVALKER » Logged
John
DFragn
« Reply #5 on: April 11, 2010, 09:18:09 PM »
My rear was pitted pretty good from road salt.
I spent several hours wet sanding them out. I got 'em, but they bled my finger tips. The I used a polishing wheel and 3 compounds.
It was a lot of work but it's practically chrome like now.
My tire was off for a new one. It can be done with rubber mounted.
John U.
Southern Delaware
« Reply #6 on: April 11, 2010, 10:07:18 PM »
This link to a Youtube video has been posted several times. It takes some rigging to get it to work. I used a spare rear axle through a couple of drilled 2x6's. 2x8's would work better. A piece of thin, hard plastic gives the wheel a slippery surface to slide on. Doing it this way still takes time and a lot of wet sandpaper but it is easier on the hands.
How to Polish a Valkyrie Wheelpowered by Aeva
Oyeaa
« Reply #7 on: April 12, 2010, 05:17:12 PM »
CHROME! Cool
Makes clean up much easier.
eric in md
« Reply #8 on: April 12, 2010, 05:22:38 PM »
ok ok ok   this is what i do for my back wheel.. put it on lift tie it down start it up put throttle lock on sos pad it first,  then put just about any polish on a rag on a stick .. hear that rag on a stick ... crank up the speed a little polish it good . look great . try it just becareful.
DFragn
« Reply #9 on: April 12, 2010, 08:09:50 PM »
 Shocked Reeeally?  Cheesy
Garland
#618
Hendersonville NC
« Reply #10 on: April 13, 2010, 10:29:34 AM »
I would end up with broken fingers, a mangled hand, and probably a dented-up bike if I tried that. Get a few Sam Adams' in me though and it might sound like a great idea!
Madmike
Campbell River BC, Canada
« Reply #11 on: April 14, 2010, 06:35:43 AM »
Has anybody tried the 3M scrubbers for starting this??
DFragn
« Reply #12 on: April 14, 2010, 06:38:46 AM »
Not if they're pitted.
daytona
Port Orange, FL
« Reply #13 on: April 14, 2010, 03:33:04 PM »
A rag spun around a drill bit (etc) on A drill of course, will buff anything with cheap turtle wax chrome polish or buffing compound. Wheel off the floor where it can be turned helps alot. I then used duplicolor clear to keep it lookin good. Works 4 me!
Just started!
