January 30, 2026, 08:12:42 PM *
Author Topic: Anybody ever have your cooling pump leak?  (Read 1772 times)
HotRod
Henderson, NV
« on: April 14, 2010, 01:03:37 PM »
 Looks like its leaking from behind it, took the cover off and the fins look good. Do i need a whole new pump or will some new o-rings do the trick? $200 plus for a new pump,yikes!
Madmike
Campbell River BC, Canada
« Reply #1 on: April 14, 2010, 02:58:46 PM »
Is the drip coming from he cover or tattle tale hole??
Michvalk
Remus, Mi
« Reply #2 on: April 14, 2010, 03:59:43 PM »
Rod, are you sure it was not leaking from the top hose, and running down? Pretty common, altho usually see the drips on the down side of the motor. Won't hurt to look cooldude
HotRod
Henderson, NV
« Reply #3 on: April 14, 2010, 04:56:23 PM »
Well I pulled it and it definitely looks like above the hole and from the back side,looks like I'll need a new pump,dang it!
Mr.BubblesVRCCDS0008
« Reply #4 on: April 14, 2010, 06:17:41 PM »
Hdl has a pump for 149. and some change.http://www.hdlparts.com/fiche_section_detail.asp?section=148910&category=MOTORCYCLES&make=HONDA&year=2000&fveh=3479
