January 31, 2026, 02:47:51 AM *
Author Topic: batwing question  (Read 2199 times)
CanadianViking
Calgary, Alberta Canada
« on: April 14, 2010, 04:15:51 PM »
Love the look of the MS Batwing and I am just curious if it is possible to have a quick connect type setup to allow for quick/easy change between the OEM Honda Tourer windshield and the Batwing?
Thomas Hansen
"CanadianViking"
VRCC Member #30753
JimC
SE Wisconsin
« Reply #1 on: April 14, 2010, 07:26:40 PM »
I don't know about the tourer windshield and the Memphis, I have the Memphis shades windscreen and the Memphis Shades bat wing, and I can switch back and forth after I get them set just right.
I really don't see a need to take the bat wing off, I like the looks, the comfort, and the protection I get from it. I guess if I wanted a change, in about 5 seconds I could have it off and riding without if I wanted.
Jim
Jim Callaghan    SE Wisconsin
CanadianViking
« Reply #2 on: May 09, 2010, 08:25:40 AM »
I was thinking when it came to long range touring that I might prefer the big OEM windshield, hence my question about being able to swap between the two.  I guess it doesn't need to be a true "quick connect", as long as the swap could be done in a reasonable amount of time.
Can any MS Batwing owners confirm that the product will work with my additional highway lights (http://gallery.me.com/hansen.thomas#100061/IMG_2412)?
Thanks!
« Last Edit: May 09, 2010, 10:57:15 AM by CanadianViking » Logged
Thomas Hansen
"CanadianViking"
VRCC Member #30753
mirion
1997 Std - 2000 IS
Frankenmuth, Michigan
« Reply #3 on: May 09, 2010, 08:54:13 AM »
My plan was to get an MS windshield like Jim so you can switch back and forth but I haven't bought the windshild yet. MS has some quick change "Trigger Lock" hardware that works with their stuff but probably not the stock Valk windsheild. Below is my 97 with MS Batwing and National Cycle lights.
JimC
SE Wisconsin
« Reply #4 on: May 09, 2010, 12:31:36 PM »
Canadianviking,
It looks like you have the same light bar that i do, I took the factory turn signals off mine and put LED's in their place. It will work just fine with that set up.
I also have the headlight relocation bracket from Darryl @        http://www.xf6-custom.com/   it brings the headlight foreword about 2 inches or more.
Jim
