January 30, 2026, 10:25:30 PM *
Author Topic: 6 carbs - when are they working?  (Read 4380 times)
Heinno
« on: April 15, 2010, 08:12:38 AM »
Hi All
I guess this question came up before, but I am new to Valks, so I don't know.
With a "normal" V-twin bike, it is easy to know when the carb or one if the two carbs is not working, but how would you know if one of six is not working. Will you even pick up if the bike is running on 5 cylinders rather than six? (I do not have any perceived problems with my bike, just wondering about this)
Let me know, thanks!!
« Reply #1 on: April 15, 2010, 08:19:43 AM »
You will know when it drops a cylinder just like ya would with your car, or your "V" twin.
When in doubt, feel for a COLD header pipe.  dead hole = cold exhaust pipe.
Redline +
Northwest Washington
« Reply #2 on: April 15, 2010, 08:21:15 AM »
When you drop a cylinder you can feel it. Just shut off the fuel while riding and test it. You will feel one drop, then two, three, four, then it starts feeling like a Harley.
Redline Cool
Heinno
« Reply #3 on: April 15, 2010, 09:56:34 AM »
Redline Cool
Aah! -  I know what a Harley feels like, so I will be on the "feel" for that - LOL!!
Thanks for the advice!!
Joe Hummer
Arnold, MO
« Reply #4 on: April 15, 2010, 10:06:00 AM »
as stated...you want to experience the bike running out of gas...next time out...just reach down and turn off the petcock.  You will feel the bike start to shudder a little as the first carb drops out...and the shudder gets worse as more drop off.  There is also a noticeable difference in the sound.
Joe
1999 Valkyrie Interstate
Larry
Northeastern BC, Canada
« Reply #5 on: April 15, 2010, 10:44:30 AM »
Ditto on the above, just starts to feel different and starts to sound like a scooter.  uglystupid2
Thunderbolt
Worthington Springs FL.
« Reply #6 on: April 15, 2010, 04:35:28 PM »
pull a spark plug wire.  You will notice the difference.  That is a good troubleshooting method if you think you have a bad plug or carb problem.  If it changes the sound, it is working.  If it does not, you have found your cylinder with problems.
Heinno
« Reply #7 on: April 15, 2010, 06:24:21 PM »
Hi, no, I do not think I have a problem, it is just with so many pistons doing the work, you might not notice a lazy one.
I am not sure how much oemf the bike should have, since I have never had one before, but it feels pretty damn good - let me assure you about that! It is just that I do not have anything to compare it with.
Tropic traveler
Silver Springs, Florida
« Reply #8 on: April 15, 2010, 07:17:18 PM »
If you are used to a "normal"  Grin Grin {what ever that is} feel of a V-twin powered bike you will notice the Valk is a different animal. Big V-twins have a lot of instant low end grunt right off idle. The Valk {or any other flat 6 powered bike} has a smoother power delivery that is more like a sport bike. The Valk will putt around real docile like at lower RPM but....... twist the throttle & get her up on the tach a bit and you will feel the difference!
Six cylinders with six carbs means six sets of ports to get the fuel/air mixture in & out veryfast. Complicates things a bit but it sure is worth it to me!! cooldude
'13 F6B red for Kim
Heinno
« Reply #9 on: April 15, 2010, 08:51:10 PM »
Yes, I have noticed! The power kicks in at about 3500rpm and counting.... Love this bike!!
Pete
« Reply #10 on: April 16, 2010, 10:53:57 AM »
To me when one drops on the road, the bike slows a little and requires more throttle to maintain set speed.  When the second one drops, same symptom, with less throttle response. When the third one drops all doubt is gone, you know it needs attention.
