January 30, 2026, 10:17:20 PM *
Author Topic: desmog freeze plug dimensions?  (Read 2570 times)
upjeeper
« on: April 15, 2010, 08:25:10 AM »
anyone have some of the freeze plugs sitting around and would mind checking them with a mic for me? If you can get me some dimensions in return i'll turn up a few for you.
I'd like to do the desmog in the near future and want to make sure of the machine shop while I can.
« Reply #1 on: April 15, 2010, 08:57:38 AM »
They are 9/16" available at any parts store.
Warlock
Magnolia, Ms
« Reply #2 on: April 15, 2010, 09:12:12 AM »
Also 14mm works.
David
upjeeper
« Reply #3 on: April 15, 2010, 09:31:09 AM »
how thick?
Thunderbolt
Worthington Springs FL.
« Reply #4 on: April 15, 2010, 04:40:22 PM »
not the flat ones.
deez
Builder of the Locost Seven on Steroids
Lee's Summit Mo.
« Reply #5 on: April 15, 2010, 09:08:51 PM »
actuall when I did my desmog,  I tapped the small port at the bottom of the holes where the  injection pipes fit in and installed 1/8" socket head pipe plugs. works great and if you "have" to go back stock for "state" reasons the original system can be installed over the top of the plug if you so chose.
partsiam
Don't gimme What IF - just gimme!
Billerica, MA - USA
« Reply #6 on: April 17, 2010, 11:42:55 AM »
After doing some reading I like the idea of leaving the pipes there and just putting some vacuum plugs on them. 3/8" does just fine. Package of 3 ran me 1.99 per.
Why bother cutting, hacking, tapping!
Bob in Billerica, MA - USA
Riding Saphira - The Blue Dragon
Y2K IS
VRCC 29281
Chromaholics 687
Darkside 276
Redline +
Northwest Washington
« Reply #7 on: April 17, 2010, 06:15:44 PM »
Because it isn't vacuum.
Redline Cool
tlanz
« Reply #8 on: April 18, 2010, 05:12:21 PM »
OK, I have a powerpoint (also PDF) with dimensions of a plug I had a buddy of mine turn up for me. It's virtually identical to the original 'plug', sans the plumbing (I used calipers on the original to get the all dimensions).  I'd attach it here, but I can't seem to figure out how to do so. Send me your e-mail addy & I'll forward it off to you.
OK, Maybe this will work?
« Last Edit: April 19, 2010, 08:15:48 PM by tlanz » Logged
Slammer
Lafayette,La.
« Reply #9 on: April 18, 2010, 05:19:20 PM »
either burn up or blow off.
larryh0841
« Reply #10 on: April 19, 2010, 05:42:42 AM »
I use 9/16" (.5625" dia.)plugs, but spin them down to .556" diameter before installing them.  The holes are about .551" diameter.  I want some press fit, but think that .011" may be too much.
Redline +
« Reply #11 on: April 19, 2010, 09:13:13 AM »
You could easily crack the cylinder head casting around the hole with to much press fit. When I machined mine I only used about .001 press and a bit of loctite. They were full length about 3/4 if I remember correctly.
Redline Cool
