January 30, 2026, 10:26:55 PM *
Author Topic: Cobra Light Bar wiring Gremlin  (Read 2676 times)
greggh
OMAHA NE
« on: April 15, 2010, 10:51:52 AM »
I recently had the fornt end apart and after putting it back together I noticed the Left blinker not working, but the Cobra spot was working.
The right blinker woked fine.
I replaced the left bulb with the right bulb and still does not work.  Now the right blinker still works but the runniing light turns off when the blinker is off.
Has anyone ever tried to rewire the light bar?
If so, is there a wiring diagram or schematics for the cobra light bar?
This thig is really ticking me off.
When I turn the left blinker on the indicator light flashes twice as fast as normally.
All fuses are fine.
help please.
Thanks In Advance.
Gregg
Joe Hummer
Arnold, MO
« Reply #1 on: April 15, 2010, 10:53:58 AM »
Check your ground connections.
1999 Valkyrie Interstate
DFragn
« Reply #2 on: April 15, 2010, 05:13:41 PM »
Ditto... grounds on turns.
The spots self-ground through the Cobra bar to the fork tubes.
Madmike
Campbell River BC, Canada
« Reply #3 on: April 15, 2010, 05:48:42 PM »
... are they grounding to the frame back through the light bucket or through the steering head bearings???
greggh
OMAHA NE
« Reply #4 on: April 15, 2010, 08:11:06 PM »
Wiring is not my speacialty, I am not sure I can find the ground from the hot.
I will dig into it either Friday or this weekend.
Will let you know the results.
Gregg
X Ring
VRCC #27389, VRCCDS #204
« Reply #5 on: April 15, 2010, 08:25:15 PM »
Honda ground wires are green.
Marty
Madmike
« Reply #6 on: April 16, 2010, 07:44:45 PM »
Gregg
Here's a schematic- select the different pages at the top to see the entire drawing.
greggh
OMAHA NE
« Reply #7 on: April 16, 2010, 07:54:09 PM »
I have that diagram in my manual.
I was hoping for a diagram for the Cobra Light Bar.
But I do appreciate it, never thought to look at that schematic.
I hope to get a look at it Saturday.
Thanks Gregg
Madmike
« Reply #8 on: April 16, 2010, 08:27:46 PM »
Thanks Gregg
should just be power and it looks like the ground is through the body of the bar........... http://www.rattlebars.com/valkfaq/circuits.html
X Ring
« Reply #9 on: April 16, 2010, 09:43:30 PM »
MM, his spots are working.  The left running light/turnsignal isn't.  It doesn't ground through the lightbar but through the wiring harness in the headlight shell.
Marty
greggh
OMAHA NE
« Reply #10 on: April 17, 2010, 12:35:17 PM »
Found it.
Now obivous wires disconnected however there was 1 wire that was loose in the connector and everything works as it should.
Thanks to all for you help.
Gregg.
