January 30, 2026, 10:17:40 PM *
Author Topic: Signallamp for neutral don't light  (Read 1955 times)
Relax
Power & elegance...just like the Valk
Oslo, Norway
« on: April 19, 2010, 12:40:47 PM »
Once in a while the green lamp indicating neutral do not light.
Is there a switch somewhere which need oil/ grease ?
lee
Northeast Tennessee
« Reply #1 on: April 19, 2010, 01:46:45 PM »
http://www.dealercostparts.com/pages/parts/viewbybrand/6/default.aspx
Neutral switch is inside front cover.  You may not want to go there.
Time is not what is taken but what remains.
C. Drewry
lee
Northeast Tennessee
« Reply #2 on: April 19, 2010, 01:49:27 PM »
Oh well try this link.  Part # 7.
http://www.hdlparts.com/fiche_section_detail.asp?section=148781&category=MOTORCYCLES&make=HONDA&year=1998&fveh=3477
C. Drewry
Thunderbolt
Worthington Springs FL.
« Reply #3 on: April 19, 2010, 04:08:18 PM »
neutral switch.  Someone was able to clean up the connector and eliminate the problem.
Madmike
Campbell River BC, Canada
« Reply #4 on: April 20, 2010, 08:48:31 AM »
The circuit grounds through the switch when it is closed.  To verify the switch you could have the ignition on, engine stopped, in and out of neutral until you get situation with bulb not lit when trans in neutral.  Turn ignition switch off, pull connector for neutral apart and check continuity to ground from the switch side of the connector.  See sheet 5 of this schematic for wiring and connector identification.
