« on: April 19, 2010, 01:28:18 PM » |
Okay, the combination of Dave's... adventure... and my own fork seal springing a leak has me concerned about all the other little things that can leave me on the side of the road in Harley Emulation Mode, so I'd like to start knocking 'em out... Also, what things should I just pay a shop to do, and which are doable by a computer geek such as myself? So far on my list: - Replace fork oil/fork seals (Will just take to a shop to do this one, that does NOT look like a fun DIY job!)
- U-Joint/Drive Shaft/Splines/Anything else in the drive train (Should I just replace all of it to be sure? U-joint was done I think about 50,000 miles ago, and I'm not finding records of when the spline or any of the other bits were last replaced, which means it was at least 30,000 miles ago)
- Had the carb's synched and valves adjusted by a shop 20,000 miles ago. Time to do again?
- The bearings in the wheels have also been there at least 30,000 miles. Should I just replace 'em all?
- I replaced the timing belt at 83,000, so it should be good for quite some time.
Any other critical things I should replace/adjust/look at, etc as I'm getting closer to the big 100,0000? I know 99% of this is in the shop manual or the tech board, but I trust ya'll's collective judgment a lot more... Thanks again!
Never ask a geek 'Why?',just nod your head and slowly back away...  IBA# 22107 VRCC# 7976 VRCCDS# 226 1998 Valkyrie Standard 2008 Gold Wing Taxation is theft. μολὼν λαβέ
« Reply #1 on: April 19, 2010, 02:18:35 PM » |
Yeowch! Just got my first quote for having the fork seals/fork oil replaced... $360... Okay, so just how bad IS that job to do???
Houdini
VRCC #28458 - VRCCDS#144
Allen, TX
« Reply #2 on: April 19, 2010, 03:11:45 PM » |
Yeowch! Just got my first quote for having the fork seals/fork oil replaced... $360... Okay, so just how bad IS that job to do??? Dave In Frisco and I did ours at a wrench party at Flyboy's and I was home in time for lunch. It is not that hard of a job to do if you have the special tools.
Valkpilot
What does the data say?
Corinth, Texas
« Reply #3 on: April 19, 2010, 03:12:15 PM » |
I'm pretty sure there's expertise in the DFW crowd. I'd like to put in Progressive front springs. Sounds like wrench party job to me.
Daniel Meyer
Moderator
The State of confusion.
« Reply #4 on: April 19, 2010, 04:58:33 PM » |
Not too bad a job. As for 100,000 miles...if you're checking the splines/pinion cup and bearings at tire changes...no need to do more than keep an eye on them. I recommend: 1) Fill 'er up. 2) Ride 'er hard.
CUAgain, Daniel Meyer
Disco
Republic of Texas
« Reply #5 on: April 19, 2010, 06:00:47 PM » |
Sounds like a it's time for the 2nd annual fork wrench party. BnB Tom didn't want to ride in the spit last April and missed the party. He still needs to / wants to / hasn't done it yet. There's 3 right there. It is not that hard of a job to do if you have the special tools. And if none of the Allen head cap screw pinch bolts refuse to cooperate...  Serk, you might start feeding them a drop or two of penetrating oil whenever you think about it in advance of the party. Sunday 2 May 2010?
2000 Bumblebee Tourer, 98 Yellow & Cream Tourer, 97 Rescue blower bike 22 CRF450RL, 19 BMW R1250RT 78 CB550K, 07 Helix 71 MT50 Trailhopper .jpg) VRCC 27,916 IBA 44,783
« Reply #6 on: April 19, 2010, 07:07:02 PM » |
If there's to be a wrenching on Sunday, May 2nd, I'll be there with bells on... Come to think of it, if there's such an event anytime that I physically CAN be there, I'll be there... What parts do I need to go ahead and order? From this page: http://www.hdlparts.com/fiche_section_detail.asp?section=148096&category=MOTORCYCLES&make=HONDA&year=1998&fveh=34662 of these - 51490-MW0-003 ? Dave - On that fiche, which ones are the allen head bolts you're referring to? I'll see if I can get 'em to budge now and start working on 'em if they won't... Fork oil - Anything particular to look for in that? Thanks again! Oh, and Daniel - I dunno what, but something ain't quite right in the rear end... Hard to explain, or even precisely put my finger on, but just something feels... sloppy... lately... Dunno how else to explain it... Has me concerned one of those bits that leaves you on the side of the road is about to give out, but I don't know enough to even know what to look for...
Stitch_in_La
« Reply #7 on: April 19, 2010, 07:15:57 PM » |
If you're just changing the seals don't need to disassemble the innards of the forks, see chets posting in tech section or I have a copy if you need it. The change I did and don't tell the spousal unit I don't think she knows I did this but you can use a large storage tub under the forks and no oil on the floor to clean up.
Chuck
RainMaker
Arlington, TX
« Reply #8 on: April 19, 2010, 07:19:05 PM » |
If it's a fork'in party, I'm in as I have the progressive springs, just haven't had a chance to mess with 'em. Also need to bleed the brakes and replace the fluids. Would it be a good idea to go ahead and replace the seals at 59K or should I just wait for them to blow out?
RainMaker
 2005 BMW R1200 GS 2000 Valkyrie Interstate 1998 Valkyrie Tourer 1981 GL1100I GoldWing 1972 CB500K1
Ghillie
« Reply #9 on: April 19, 2010, 07:34:54 PM » |
Offering to host at my place again. In the process of cleaning out down here. All the repo Harleys should have gone to auction by then. The weather should not be too bad and I can grill or we can ride somewhere east for some chow. I need to replace the intake o rings and the exhaust mani gaskets, replace the choke cable which seems to be mostly stuck at this point, as well as would like to sync the carbs.
Serk, anytime you want to wrench and not mess up your garage floor, you are welcome here. I am kind of like you. I have been leary of taking a serious road ride since I don't know what was done when if ever in my case. I am always looking to learn how to work on my girl.
When the people fear government, there is tyranny. When government fears the people, there is liberty.
Disco
Republic of Texas
« Reply #10 on: April 19, 2010, 08:40:07 PM » |
Dag has a good write-up here: http://www.valkyrienorway.com/forksprings.htmlWanderer has been into forks several times recently. Maybe he'll chime in. Serk, the bolts I referred to are #10 on the Steering Stem fiche and #15 on the Handlebar @ Top Bridge fiche. One of Chuck's was seized up tighter than dammit.
« Reply #11 on: April 19, 2010, 09:04:15 PM » |
Dave - Cool, just went out to the garage and checked, all 6 of those bolts (2 on the bottom, 1 on the top on each side) were easy enough to break loose... I'm guessing we can skip a lot of steps in Dag's instructions, since I don't wanna replace the springs (Already put Progressive's in there, or rather, paid to have them put in, several years back), just need to replace the seals and the oil... What parts should I order just for that? Everything Dag ordered, or just a subset of that? (Sorry for such stupid questions, I've always had a bit of a mental block related to wrenching. I can usually grunt my way through what needs to be done, but it can get ugly if I try to do too much solo...) Ghillie - Appreciate it. Unfortunately, I have no one but myself to blame for any of the maintenance of lack thereof on my bike... This is how many miles were on the clock when I bought it...
Houdini
Allen, TX
« Reply #12 on: April 20, 2010, 03:20:34 AM » |
One of Chuck's was seized up tighter than dammit. Still is! One of these days I'll get some oil and the heat gun out and try to get it out again...
Daniel Meyer
Moderator
« Reply #13 on: April 20, 2010, 05:07:08 AM » |
With the miles you have on (and your petite self) I'd also replace the wearable parts...as in the bushings. BUSH, GUIDE 51414-MT7-003 BUSH, SLIDER 51415-MCH-003 2 of each of those... Oh, and Daniel - I dunno what, but something ain't quite right in the rear end... Hard to explain, or even precisely put my finger on, but just something feels... sloppy... lately... Dunno how else to explain it... Has me concerned one of those bits that leaves you on the side of the road is about to give out, but I don't know enough to even know what to look for...
Time to take it apart and look then. Bearings, ujoint, pinion cup, swing arm bearings...all can be checked out without replacing. It's a solid bit of work though when you include the ujoint. You ever replace your rubber wheel dampaners?
Houdini
Allen, TX
« Reply #14 on: April 20, 2010, 06:46:00 AM » |
I'd also replace the wearable parts...as in the bushings. I concur, at 85K my bushings were completely worn out.
« Reply #15 on: April 20, 2010, 07:03:45 AM » |
I'll hafta tackle that one with assistance too... It all looked okay to me when I had the rear off a few weeks ago, but I just don't know what I'm looking for... Can you tell ANYTHING from this pic?  Here's a link to the full resolution version - http://www.serk.net/akpics-7-8/images_111/IMG_4851.JPGThanks again for the help, and ya'll's patience!
Disco
Republic of Texas
« Reply #16 on: April 20, 2010, 07:21:50 AM » |
It's hard to tell through all the pookie, but do I see some wear on the teeth at 11-12 o'clock on the hi rez?
Daniel Meyer
Moderator
« Reply #17 on: April 20, 2010, 07:22:17 AM » |
Hmmm...hard to tell from the pic due to the grease...but that could be some wear there.
Gotta pic of the male (star on the wheel?)
Daniel Meyer
Moderator
« Reply #18 on: April 20, 2010, 07:24:49 AM » |
Here is what you are looking for...
Wanderer
« Reply #19 on: April 20, 2010, 07:37:00 AM » |
One of Chuck's was seized up tighter than dammit. Still is! One of these days I'll get some oil and the heat gun out and try to get it out again... If you can get some candle wax in the tensioner crack and heat it up and into the treads, that works better than any penetrating oil! Especially effective on brake caliper bleed screws! Vanilla scent works best. ~Jeff
More Valk Pics...had a couple of Valks once upon a time 2004 DRZ400S 2005 GS1200 1978 CB550K 1977 CB550F
« Reply #20 on: April 20, 2010, 07:50:08 AM » |
Ahhhhh, okay... Thanks for the pic Daniel, makes more sense now... I seem to have taken pics of everything in sight that day, EXCEPT for the gears on the wheel side...
I'm on vacation this week though, so I just might go pull the rear wheel again and have a look see at what I can see now that I've got a little better idea what I'm looking for...
Thanks again!
godfire
Republic of Texas
« Reply #21 on: April 20, 2010, 09:36:39 AM » |
Here is what you are looking for...  Daniel, I'm confused....should they glow red.....or is glowing red a problem.....
Ride Safe Ride Often
Houdini
Allen, TX
« Reply #22 on: April 20, 2010, 09:56:24 AM » |
should they glow red.....or is glowing red a problem..... They're red hot because they don't have any grease on 'em!
RainMaker
Arlington, TX
« Reply #23 on: April 20, 2010, 12:12:55 PM » |
should they glow red.....or is glowing red a problem..... They're red hot because they don't have any grease on 'em! And Vermithrax knows about no grease on splines. I remember.
Mr.BubblesVRCCDS0008
« Reply #24 on: April 20, 2010, 01:27:51 PM » |
Wanderer, you worry me when you start talking about hot candle wax and penetration oil.
« Reply #25 on: April 20, 2010, 07:50:11 PM » |
Okay... Took the rear tire off, and here's what I found... The 5 pronged bit that goes into the wheel I THINK is okay. There is some wear on it, but the teeth are mostly intact:  High-Res version - http://www.serk.net/akpics-7-8/images_153/IMG_7894.JPG High-Res version - http://www.serk.net/akpics-7-8/images_153/IMG_7898.JPGHowever... The teeth on the bit that stays on the bike and meshes up with the bit that goes with the wheel... Not so much... The teeth on it appear to be about 1/2 the size as the teeth on the first part...  High-Res version - http://www.serk.net/akpics-7-8/images_153/IMG_7920.JPG High-Res version - http://www.serk.net/akpics-7-8/images_153/IMG_7899.JPGSo, I'm guessing at the very least I need to replace the gear (Is that the infamous "splines" people are always talking about?) on the part that stays on the bike. That was as far as I'm comfortable going in disassembling things, but if those gears are that chewed up (If I'm reading that right) is it pretty safe to assume the others prolly need replacing too? How ugly is it to keep going on the dis-assembly from here to verify, or should they all be replaced as a set anyway? Once again... My great gratitude for ya'll's assistance and patience!
Daniel Meyer
Moderator
« Reply #26 on: April 21, 2010, 06:27:09 AM » |
The splines in the rear end are somewhat difficult to replace (and expensive).
The star on the wheel is not, but they should normally be replaced as a set as sticking a new one with an old one will VERY rapidly wear the new one down to match the old.
But yep...your rear-drive looks all used up.
Might pay to pick up a used one from Pinwall or ebay or such...they can generally be had for under $200 (parts to fix the rear pumpkin will be much more than that). Make sure they include the star for the wheel and pics that show neither are worn (or will exchange a bad one).
Daniel Meyer
Moderator
« Reply #28 on: April 21, 2010, 10:23:23 AM » |
Those are them!
-dm
« Reply #29 on: April 21, 2010, 06:15:54 PM » |
...and the ugly reality of the financial adviser rears it's head...
So... Do I get any kinda warning right before the rear drive gives up the ghost for good and I'm stuck on the side of the road, or have I already had my warning?
Also, I know it needs to be fixed, but how critical is the front fork seal leaking? Is that a "Park it NOW!" thing, or does it just mean things will be a lil' awkward 'till I get it taken care of?
Hate to totally park the Valk 'till we can get the fundage for parts, but don't wanna hafta be calling someone to tow me in either... (I'm starting to better understand people who have 2, 3 or more Valks now... I'm SO glad I've at least got the spousal unit's ST1300 at times like this, although I can't ride it too long, it destroys my back.)
Valker
Wahoo!!!!
Texas Panhandle
« Reply #30 on: April 21, 2010, 06:22:36 PM » |
I have had a leaking fork seal for 2 years and many thousands of miles. Looks messy, but I keep it off critical components. I plan to change the seals this year.
Houdini
Allen, TX
« Reply #31 on: April 21, 2010, 08:02:51 PM » |
So... Do I get any kinda warning right before the rear drive gives up the ghost for good and I'm stuck on the side of the road, or have I already had my warning? Serk, those gears look brand-spankin' new compared to what mine looked like before I changed them out. You may not want to plan any cross country trips but I'd keep riding her until you find your parts.
Daniel Meyer
Moderator
« Reply #32 on: April 22, 2010, 05:09:23 AM » |
Fork seal leaking is no big deal. There is a LOT of oil in that fork...and even if it was nearly dry the only thing that would happen is your suspension would get bouncy and it might wear the bushings (which you're going to replace anyway). I think all the parts together for both forks should be around $60 or so. As far as the rear end...that's a good question. I expect IF you assemble it correctly and with lube, it should last quite a bit longer. Did you inspect the pinion cup? That's the one more likely to leave somebody standing.
« Reply #33 on: April 22, 2010, 09:33:26 AM » |
Googling trying to find out what the "Pinion Cup" was, found this post of yours (Daniel's): The rear drive splines wear because folks install the rear tire incorrectly. You need to loosen the 4 bolts that hold the pumpkin to the swing arm BEFORE you torque the axle, then tighten them afterwards. This is for alignment and has been a necessary thing since the early goldwings on this drive. Also check the pinion cup frequently. There are also 3-rings that should be replaced in the rear wheel when changing...look at shoptalk again, great article on that. (Seriously... Google on "Valkyrie pinion cup" and that post is the 2nd hit!) I've searched the Tech board, Googled on it, and looked through the parts fiche sites... What exactly is the pinion cup, and what do I look for to check for wear, and I'll go tear the rear end down again... I'd never heard about loosening the 4 bolts holding the pumpkin in, then torquing the axle down... Guess I'm back out to the garage to redo that bit today... Once again... Thanks!
« Reply #35 on: April 22, 2010, 10:32:05 AM » |
Groovy, appreciate it Mr. Bubbles...
So, pull the wheel, undo the 4 bolts that hold the pumpkin on, pull it off, and look for that part in all the parts that will come out, basically?
Daniel Meyer
Moderator
« Reply #36 on: April 22, 2010, 10:42:29 AM » |
Sort of...pull the 4-nuts, grab the pumpkin and pull it out. The driveshaft will come with it.
The driveshaft mates to the pumpkin at the pinion cup (they should always be changed as a set).
Put a towel/such down (so you don't scuff/crack your pumpkin), pick the thing up by the driveshaft and hold it a 1/2" above the towel and tap the cup on the side with a hammer. Should pop apart. If it looks rusty/dry shoot in the seal with some wd-40 or something and it should come apart.
That joint is not really splines...it has some flex...and is subject to wear. It's lubed by the rear end and tends to clog up with crud, preventing the lube from doing it's job. It really should be cleaned, inspected, and lightly lubed and reinstalled at every tire change or so.
And if worn...replace it. This is the one that tends to strand riders.
To reinstall, stick the driveshaft back in the cup, make sure the seal is all the way in the cup, prop the swing arm ABOVE horizontal (this is key), stick the shaft in the swing arm, get the 4 studs started in the holes, and wiggle the hell out of it. It will go right into the ujoint. (If the pumpkin goes all the way in, the shaft is in the ujoint...it can't go beside/around it).
« Last Edit: April 22, 2010, 10:44:06 AM by Daniel Meyer »
« Reply #37 on: April 22, 2010, 03:27:28 PM » |
...so is it a bad thing if, as you pull the pumpkin, a large visible cloud of rust dust shoots out of the drive shaft enclosure? Thanks for the prodding, I don't think the pinion cup had much left in it before leaving me on the side of the road... The inner part of the gears are MAYBE the thickness of a thick piece of paper...  (The outer facing part of the teeth look thick, but just behind the outer face they fade out to almost nothing.)  The driveshaft, besides being very rusty, doesn't look to be in much better shape:   Investigating replacement options now... I've got a lead on some parts local I'm gonna check out... As annoying as this is, I'd MUCH rather have the bike apart in the confines of my garage and find out about it NOW then somewhere out on the road!
Rocketman
« Reply #38 on: April 22, 2010, 03:38:20 PM » |
YIKES!!! Good catch.
Disco
Republic of Texas
« Reply #39 on: April 22, 2010, 03:44:26 PM » |
I'd MUCH rather have the bike apart in the confines of my garage and find out about it NOW then somewhere out on the road! +1!
