January 30, 2026, 10:17:38 PM *
Author Topic: Pingel question  (Read 2408 times)
NEHI
« on: April 19, 2010, 04:47:33 PM »
     For you that have installed a Pingel valve, do you use just the o-ring that was on the tank, just the plastic washer that was supplied with the valve, or both?
     Dean..
« Reply #1 on: April 19, 2010, 04:57:45 PM »
Use the plastic washer that came with the Pingle.
junior
new hampshire
« Reply #2 on: April 20, 2010, 12:20:57 AM »
ditto, and i also had to replace that first section of fuel line from the petcock to the T fitting from the hinda silicone hose to a real rubber hose.(i used 5/16th) cause the honda hose wouldnt seal on the pingle nipple
« Reply #3 on: April 20, 2010, 06:28:18 AM »
Use a small hose clamp, the screw type and there will be no problem.
Actually doing it this way makes it a simple operation when times comes for removing the hose.
The hose just slides off cleanly.
paul
« Reply #4 on: April 21, 2010, 05:21:14 AM »
Your gonna appreciate that valve compared to the oem. cooldude...dont forget to plug the vac port #6......and maybee send out your engine hangers to get chromed!!!
« Reply #5 on: April 21, 2010, 05:27:42 AM »
Or attach a chrome Stebil Horn...thats how I covered the hole left by switching to a Pingel...these things are handy to scare Vultures off the road way ahead of you.......scare people that are texting while driving good enough that the phone gets tossed into the back seat, and definetly the primary purpose, if someone is trying to occupy the space you are already in, this horn WILL MAKE THEM STOP and reconsider their move!!!!!!
paul
« Reply #6 on: April 21, 2010, 06:31:15 AM »
Thats a good idea,,,,the oem horn not so good....havent heard the stebil,,,,saw car horn at napa the other day..said 117db i think,,,
« Reply #7 on: April 21, 2010, 07:04:52 AM »
Stebil is like 140db
X Ring
VRCC #27389, VRCCDS #204
« Reply #8 on: April 21, 2010, 07:37:55 AM »
Mine is mounted in the same place ChrisJ's is and he's not lying about scaring vultures with it.  I was on a country road when I saw buzzards in the road about 40-50 yards ahead.  Tapped the horn and they took off like I fired a gun.   cooldude
Marty
N0tac0p
« Reply #9 on: April 21, 2010, 08:13:54 AM »
i am looking to do this conversion along with the quick disconnect (if possible), plus someone said something about putting in an electric valve?   are there any pics and instructinos for all this install.  sounds like a lot of guess work that could end badly.  any pics, instructions would be greatly appreciated, thx all.
John U.
Southern Delaware
« Reply #10 on: April 21, 2010, 01:21:28 PM »
Do a search for: Dan-Marc fuel valve". Plenty of info.
