March 16, 2026, 07:21:15 AM *
Author Topic: Memphis shade batwing  (Read 1304 times)
Davitaia
Maryland
« on: April 22, 2010, 07:56:32 PM »
Memphis batwing for standard, what you guys think if you use it. Do you like it, does it do the job, what size windshield do you use, where is the best place to get it for good price.
Thanks guys
David
JimC
SE Wisconsin
« Reply #1 on: April 22, 2010, 10:00:35 PM »
I like mine, it seems to do the job very well. I have a 13 or 14 inch windshield from a different supplier. When I ordered my Memphis shade the largest they made was a 9 or 10 inch, if I remember correctly.
Right now, the cheapest I have seen is a little under $200 on ebay, then they ad the cost of the mounts and shield, and trim if you want it. That should put it at about $350 maybe a little less. It is not fancy, but it is basically the same shape as the fairings that are selling for 2-3 or 4 times as much.
If you do buy one, get in touch with Darryl at
www.xf6-custom.com/
he is making a headlight re-location bracket to bring the headlight out of the fairing a couple inches,
plus I believe he is going to be selling polished stainless wind deflectors for the bottom edge of the fairing rather than the cheap plastic ones that Memphis sells.
Jim
« Last Edit: April 22, 2010, 10:06:55 PM by JimC » Logged
Jim Callaghan    SE Wisconsin
Jack B
Two Rivers Wis
« Reply #2 on: April 23, 2010, 05:32:26 AM »
Check out this site
http://valkyrie-owners.com/SMFORUM/index.php/topic,9076.0.html
Let’s RIDE
wizard -vrccds#125
Hitchcock Tx.
« Reply #3 on: April 23, 2010, 10:20:05 AM »
The headlight relocation bracket did not work at all on mine! Bought it because I was told it would help in mounting. I had to pull it off and waisted $75.
