January 30, 2026, 11:44:02 PM *
Author Topic: popping or burbling  (Read 2696 times)
TGViper
« on: April 22, 2010, 09:02:34 PM »
Hey - new to the forum and the Valk - love the bike but would like to know if the followin is "normal".  On decel, is it normal to have burbling (not full fledge back firing) - more like burbling to popping sounds.  Comes from both pipes, not just one.
Runs like a scalded dog otherwise and idles fine.  Getting 125 to a tank in town.
Thanks in advance,
TGViper
blackcat
Nicholas Vore VRCC # 30301
Mounds, Arkansas
« Reply #1 on: April 22, 2010, 09:40:06 PM »
sounds like you need to perform a desmog
______________________
03 Standard -Fast Black
00 Interstate - Red/Black
97 Tourstate - Yellow/Ivory
2010 Goldwing - Pearl Yellow
Valker
Wahoo!!!!
Texas Panhandle
« Reply #2 on: April 23, 2010, 05:07:21 AM »
When mine did that, it was cracked and split vacuum hoses.
TGViper
« Reply #3 on: April 23, 2010, 06:07:58 AM »
Assume to fix this you pull the tank and replace vacuum hoses to the carbs - correct?
As for the Desmog - I'll use the search button to figure that one out.
« Reply #4 on: April 23, 2010, 06:25:14 AM »
Nope.
It's the hoses that connect to the intake risers. There at the bottom of each is a hose barb. Some are capped and some have hoses.
Yes, you have an easier time pulling the gas tank and air box to do this.
Lost Valk
« Reply #5 on: April 23, 2010, 05:00:50 PM »
I agree about the vacuum lines.  I found a couple of the capped ones most likely to split.  You can check those without pulling the tank and very little work.  Just look/feel.  I forget which cylinders are deadened vs hosed.  Anytime i have had the cracking it was at the connections and not just randomly in the hoses.  Hope that helps.
« Reply #6 on: April 23, 2010, 06:27:00 PM »
This condition is caused by too much air entering the intake/exhaust system. The common causes are vacuum lines dry and cracked: O rings at the base of the intake runners old: exhaust nuts loose (5-7 FT/LBS): hose clamps at carb inlet loose. O rings are a #123 and can be bought at an industrial supply. Get them in Viton or silicone. Vacuum lines are 3.5 mm or a 5/32nd" . I bought Honda's OEM and haven't had any more trouble in 3 years of almost daily use.
mikeb
vrcc-29271
dansville mi by lansing mi
« Reply #7 on: April 23, 2010, 06:36:54 PM »
the best place to look and spend some time reading  is here
http://www.valkyrieriders.com/shoptalk/
i dont care what you ride just ride
mike & kari
mivrcc capital city leader
s.s.d.d.
bigdog99
1/1/2011 86,000 miles
Kouts Indiana
« Reply #8 on: April 24, 2010, 09:10:53 AM »
i also found that the carbs can be slightly out of sinc and get theat, when i learned to sync my own, it was amazing that the noises smoothed out on de-cel, i get about 200 miles at loewr speeds to a tank, figured i wasnt as rich any more.
VRCC#31391
VRCCDS0239
Lost Valk
« Reply #9 on: April 24, 2010, 10:18:29 AM »
I have never synced my carbs in the 6-7 years i have owned mine.  I have always meant to get around to learning/doing it.  I just hate touching carbs Sad
NITRO
Eau Claire, WI
« Reply #10 on: April 24, 2010, 10:30:00 AM »
I had the same problem. Replacing the split lines (one had a huge hole in it) helped a lot. I also had to replace the intake o-rings as two were leaking badly this spring and two others were just beginning to leak. That took care of all the popping.
When in doubt, ride.
bigdog99
Kouts Indiana
« Reply #11 on: April 24, 2010, 12:42:21 PM »
sync really doesnt touch the carbs, but i am with you when it comes to jets, needles, etc. really hope i never have to! though there is enough info on this site i would have to read a lot before i did. but i am confident with the way information is shared here it would be something new to learn, uglystupid2
VRCC#31391
VRCCDS0239
TGViper
« Reply #12 on: April 24, 2010, 03:50:13 PM »
200 miles?  Do you have an IS or reg?  I got 125 miles just tooling around before going on reserve.
Viper
bigdog99
Kouts Indiana
« Reply #13 on: April 24, 2010, 03:56:10 PM »
Sorry,
IS
VRCC#31391
VRCCDS0239
TGViper
« Reply #14 on: April 24, 2010, 08:07:10 PM »
Sorry,
IS
Ahhh - that explains it then.  I am thinking about adding the belly tank.
Mr.BubblesVRCCDS0008
« Reply #15 on: April 24, 2010, 09:31:02 PM »
Also check the clamps on the airbox to carb and carb to intake running if they are loose popping can result.
