January 30, 2026, 11:44:02 PM *
Author Topic: Thinkin' 'bout...  (Read 2230 times)
Printer Mike
Eatonton, Georgia
« on: April 22, 2010, 11:22:31 PM »
goin' back to the stock pipes that came with my used Cobra 6 into 6 exhaust equipped '98 Tourer. I took the stock pipes out of the box for the first time, and was surprised at how clean and scratch/dent free they are.
If I switch 'em back to stock, I was wondering if there's anything I need to watch out for... The previous owner said he never re-jetted. The Cobras are real blue/black about the first foot or so, plus the beautiful sound does get a little annoying on a long ride.
Thanks for any tips.
Never give up!
fstsix
« Reply #1 on: April 23, 2010, 04:43:25 AM »
I hear ya on the long ride LOUD pipes, Watch out for a 7-10 HP increase if not re jetted, I like the Drag pipes looks and sound but, scavenging for a unblown motor will increase HP. I have Vikings and they also get to be a headache after 4-5 hr's, But my Wife Loves the sound LOL!!!
Red Diamond
Beaumont, Texas
« Reply #2 on: April 23, 2010, 07:19:49 AM »
I've never removed the exhaust system on the bike, not even to remove the rear wheel, but others always mention the torque of the flange bolts. Be careful not to over torque as they will twist off.
X Ring
VRCC #27389, VRCCDS #204
« Reply #3 on: April 23, 2010, 09:17:04 AM »
Use liberal amounts of penetrating oil on the exhaust flange nuts and allow them to soak for a while.  Then spray them again before putting a wrench on them.  Use steady pressure don't snatch them or the studs will break.
Marty
Gunslinger
Brian Huntzinger, EMT-P
Wamego, KS
« Reply #4 on: April 23, 2010, 12:11:49 PM »
Lots of penetrating oil (You might try the Acetone/Trans fluid mix referenced here before) and go easy getting them off.
When you tighten things back up, follow the recommended torque specs. Then recheck every hundred miles or so until they stay tight.
VRCC#   26468
VRCCDS# 0228
"Some learn by listening, Others learn by watching...
The rest of us have to pee on the electric fence ourselves"
Redline +
Northwest Washington
« Reply #5 on: April 23, 2010, 01:00:09 PM »
I just switched from Cobras to unmolested  IS pipes. The first thing I noticed was the transmission whine, the second was front tire noise. I had read about both but never heard them before. You will enjoy the quiet exhaust.
It does take awhile to get the new exhaust gaskets crushed to hold torque. A little anti-seize on the studs and torque to about 70 - 80 inch lbs. Ride, let cool, retorque and repeat. I think it took 5-6 times on mine.
Redline Cool
Red Diamond
Beaumont, Texas
« Reply #6 on: April 23, 2010, 02:26:50 PM »
Redline Cool
[/quote]Don't want to hijack this thread, but I'm going to throw a big wrench into this one for Redline. Install some Mobil 1 15-50 into that crankcase and you won't hear anymore transmission whine. You won't hear any whining from me either.
My Two Favorite Bikes
Dave Weaver
Seymour, IN
« Reply #7 on: April 23, 2010, 06:04:18 PM »
Get some new exhaus washers and a few new studs in case some do break.  Look in the Cobra's after removal and up into the exhaust ports to make sure all of the old gaskets get removed.  They have a tendency to hide from ya.
Do unto others as you would have them do unto you.
Printer Mike
Eatonton, Georgia
« Reply #8 on: April 23, 2010, 10:27:17 PM »
I really appreciate the comments and tips. Thanks! cooldude
Never give up!
