January 30, 2026, 11:43:49 PM *
Author Topic: Installing OEM screen  (Read 1755 times)
recall
Bournemouth Dorset United Kingdom
« on: April 23, 2010, 07:54:53 AM »
Hi all  cooldude,
                        While i've been waiting for my cash to arive i thought (gonna get an Interstate then) i would fix the OEM windscreen to my standard as it has been sitting around since xmas.. Easy enough.. only thing is i'm a little heavy handed.. the rubber washers that come with it.. sorta squeesed them out a bit.. so my question is have any of you replaced these rubber washers.. with anything else.. if so what and where can i get it.. Cheers
What you see is what you get...
Black Dog
VRCC # 7111
Merton Wisconsin 53029
« Reply #1 on: April 23, 2010, 08:47:13 AM »
If you are talking about the rubber washers that go between the upper W/S mounts, and the 'special steel washer', they detoriate very quickly...  I went to the hardware store, and went through all the rubber washers and 'O' rings in the place, and didn't find ones the correct size...  Ended up buying rubber washers, that had smaller holes than the OEM, and used a hand held 'paper punch' to make the holes large enough for the mounting bolt, and steel washer collar to pass through...
Gotta get creative  uglystupid2  If ya don't want to pay the price for the Honda OEM's.
Black Dog
Don't you know...
recall
« Reply #2 on: April 23, 2010, 03:46:18 PM »
them's the ones.. i too had thought about a thicker / harder rubber or a hard resin washer.. still on the look out for a replacement.............
