January 30, 2026, 11:43:51 PM *
Author Topic: Battery Chargers - how do you know when they are no longer doing the job  (Read 1616 times)
Rowdy
Nerk, Ohio
« on: April 23, 2010, 08:25:09 AM »
 Sad I have accumulated several actually many  Undecided chargers and tenders over the years - has anyone found a sure fire method of checking a charger and / or a tender - I'd would like to weed them out and get rid of the bad ones  Roll Eyes
I know some won't register anything, some need to be attached to a battery with some juice left in the battery  uglystupid2  If I hook them to a battery (That has some life) I should get reading from a volt meter when attached - right  ? Or am I just getting a reading volts from the battery  ???
Anyway - has anyone found a fool proff method to verify if a battery charger / Tender is till doing what it's suppose to do  Cheesy
Cleaning out the garage of obsolite stuff  Grin
Rowdy
99 Gr / Sv I/S
81 Bl CB900 Custom
73 Bl CL350 (sold)
06 Tit GL1800
77 GL1000 naked wing (Sold)
86 & 84 GL1200 wings (Sold)
Semper Fi "Leathernec
3W-lonerider
Shippensburg Pa
« Reply #1 on: April 23, 2010, 01:49:07 PM »
sure fire method..hook up a volt meter to the battery and read the voltage. then with the meter still hooked up..plug in the charger..if the voltage increases the charger is putting out.
