January 30, 2026, 11:44:06 PM *
Author Topic: Lost spacer from behind left side engine hanger  (Read 2245 times)
Cliff
Manchester, NH
« on: April 23, 2010, 07:24:52 PM »
Lost spacer from behind left side engine hanger while installing engine hanger cover,,, heard the tink tink as it fell but cannot find it.   Need a new one but cannot find it.  It sits behind the engine hanger and bolt 30 goes through it doesn't show on this drawing (frame): http://www.hdlparts.com/fiche_section_detail.asp?section=148631&category=MOTORCYCLES&make=HONDA&year=2000&fveh=3474
VRCC # 29680
DFragn
« Reply #1 on: April 23, 2010, 08:20:04 PM »
Look under ignition coil on the parts fiche.
02     COLLAR, PIVOT
17937-881-000    004    $6.02    $4.21
No. 2
Or, it's likely hiding down low between the alternator and rear engine case. That pocket is a catch-all. A small flexible magnet may retrieve it for you.
Cliff
Manchester, NH
« Reply #2 on: April 24, 2010, 04:40:13 AM »
02     COLLAR, PIVOT
No. 2
I'll have to try and locate a small flexible magnet, I have tried feeling in that area with fingers but I'm sure you already know that doesn't get in there very far  Sad
EDIT:  Forgot to tell you thanks for pointing out where I can find the part on the fiche!! cooldude
« Last Edit: April 24, 2010, 05:44:50 AM by Cliff » Logged
VRCC # 29680
« Reply #3 on: April 24, 2010, 09:20:04 AM »
With a mirror and a flashlight you can see a whole lot looking up from under the motor.
Especially easy to see that space between the alternator and the motor case.
Cliff
Manchester, NH
« Reply #4 on: April 26, 2010, 04:52:27 AM »
Bought a small flexible magnet and shure enough found it in the crevice next to the alternator and was able to "fish" it out.  That was easy compared to re-attaching the breather hose which came up with it.  Thanks very much for the suggestion.  cooldude
VRCC # 29680
DFragn
« Reply #5 on: April 26, 2010, 07:37:10 AM »
Oh yeah, meant to warn you about the lines.
Now you're ready for the "next time".  cooldude
