January 30, 2026, 11:44:51 PM *
Author Topic: I stole this from the TEMP board - Thanks Tracy.  (Read 1902 times)
« on: April 24, 2010, 05:04:15 AM »
Penetrating Oils Compared
Machinist's Workshop magazine actually tested penetrants for break out torque on rusted nuts. Significant results! They arranged a subjective test of all the popular penetrants with the control being the torque required to remove the nut from a "scientifically rusted" environment. Results relative to 'naturally rusted' conditions considered equivalent in standing.
Penetrating oil ........... Average load
None ..................... 516 pounds
WD-40 .................... 238 pounds
PB Blaster ............... 214 pounds
Liquid Wrench ............. 127 pounds
Kano Kroil ............... 106 pounds
ATF-Acetone mix............ 53 pounds
The Automatic Transmission fluid (ATF)-Acetone mix was a "home brew" mix of 50 - 50 automatic transmission fluid and acetone.
Note the "home brew" was better than any commercial product in this one particular test. A local machinist group mixed up a batch and all now use it with equally good results. Note also that "Liquid Wrench" is about as good as "Kroil" for about 20% of the price
« Last Edit: April 24, 2010, 05:06:06 AM by R J » Logged
« Reply #1 on: April 24, 2010, 01:05:37 PM »
Highbinder's post on the General Board
« Reply #2 on: April 24, 2010, 05:02:58 PM »
AND Tracy's post on the Temp board.
Never saw Don's and still haven't seen it over there.
Thanks anyway Sarge.
Sodbuster
« Reply #3 on: April 24, 2010, 08:00:58 PM »
Good info .... thanks for sharing
VRCC # 30938
