March 07, 2026, 01:52:26 AM *
Author Topic: Lift Adapter  (Read 3007 times)
Bigdog
Russell , Kentucky
« on: March 14, 2009, 11:04:42 AM »
I have a question, I bought a small lift adapter for my valkyrie. But I'm wondering if it is strong enough?  It is made to bolt onto the two kickstand bolts, just wondering if anyone has one?  It is not very big kind of made like an  " H "...Thanks.....Mike
This country, with its institutions, belongs to the people who inhabit it. Whenever they shall grow weary of the existing government, they can exercise their constitutional right of amending it or their revolutionary right to dismember it or overthrow it." -- Abraham Lincoln, 4 April 1861
« Reply #1 on: March 14, 2009, 12:21:22 PM »
What size material is it made of. I had one welded up years ago and it would handle twice the weight of a Valk. Doesn't bolt to the kickstand attachment points though.
« Reply #2 on: March 14, 2009, 12:22:08 PM »
Does it have a leg out theleft side to stand on to raise the bike?
If so, you have a Rivco center stand............
Does it look similair to this?
This one is for a Harley, couldn't find the Valkyrie one on their site.
Mr.BubblesVRCCDS0008
« Reply #3 on: March 14, 2009, 01:30:16 PM »
I remember those they bolt below the kickstand using the same bolts and them your regular ATV jack will have a flat area to lift the valk. They just replace the 2x4 blocks on the wood adapter. It stays with the bike all the time. Looked plenty strong to me.JMHO
AussieValk
Gold Coast, Australia
« Reply #4 on: March 15, 2009, 07:11:16 AM »
I've got one of those permanent ones on. They're fine and plenty strong enough. The paint might be a bit thin though as mine has chipped on the front side and needs touching up.
frosty
« Reply #5 on: March 15, 2009, 04:51:20 PM »
If you do get the kickstand one, be sure its the stronger one with duralast coating. Or the best support adapter is the one that runs beneath the engine also on e-bay. A little more but well worth the bucks for the peace of mind.
Duffy
Atlanta, GA
« Reply #6 on: March 15, 2009, 05:31:57 PM »
You can make a simple one with help from here:
http://www.herberts.org/wayne/valk/lowtechlift.htm
Works fine for me.   Wink
f-Stop
'98 Standard named Hildr
Driftwood, Texas
« Reply #7 on: March 15, 2009, 06:19:40 PM »
Here's my version...
Oil Drain Hole
I use a jack stand for extra stablility
Low Tech - Made with spare wood found in my garage, a little wood glue and deck screws.
