January 30, 2026, 11:44:07 PM *
Author Topic: High pitched whine/whistle  (Read 2187 times)
Farther
Quimper Peninsula, WA
« on: April 25, 2010, 04:31:09 PM »
I have started to notice a high pitched whine/whistle at 55 mph, 5th gear and 2500 RPM on my '03 Standard.  The noise does not apperar to be present at 2500 rpm in any other gear, however I would not rule out engine noise canceling out the whine/whistle in other gears.  Anybody have experience with this?
~Farther
Bone
« Reply #1 on: April 25, 2010, 04:42:57 PM »
What if you pull in the clutch lever at 55 does the whine stop ?
Farther
« Reply #2 on: April 25, 2010, 04:47:29 PM »
Ya, the noise does stop.
~Farther
« Reply #3 on: April 25, 2010, 05:14:00 PM »
The gears whine on my Valk at 55 mph, It's normal, one reason I use earplugs.  hoser
Sraight pipes will cure it too.  At least you won't hear it, or anything else!  Cheesy hoser
« Last Edit: April 26, 2010, 11:42:15 AM by Hoser » Logged
« Reply #4 on: April 25, 2010, 05:26:05 PM »
Switch oils some help it quiet down other wise its normal  Grin
Farther
« Reply #5 on: April 25, 2010, 05:27:59 PM »
I use Mobil 1 motorcycle oil.  I don't think a change of oil will help.  However I have two gallons of Amsoil motorcycle oil in the barn for the next two oil changes.
~Farther
Red Diamond
Beaumont, Texas
« Reply #6 on: April 25, 2010, 05:35:10 PM »
The square cut gears  do whine, Mobil 1 15W-50.
asfltdncr
« Reply #7 on: April 26, 2010, 08:13:28 AM »
and earplugs. cooldude
Redline +
Northwest Washington
« Reply #8 on: April 26, 2010, 01:00:51 PM »
I have started to notice a high pitched whine at 55 mph. Anybody have experience with this?
Yes...ride faster. cooldude
Redline Cool
Farther
« Reply #9 on: April 26, 2010, 01:52:15 PM »
Yes...ride faster. :cooldude:Redline Cool
Ya, I have been taking it easy on some mountain and river roads.  The upside is my fuel mileage has ranged from a low of 35 mpg to a high of 46.6 mpg with an average of 40 mpg.  This is up from my usual of 33 mpg.
~Farther
