January 30, 2026, 11:43:54 PM *
Author Topic: Velocity Stack Air Fliters Question  (Read 2054 times)
BIG COUNTRY 23321
Me & My Death Horse
Chesapeake, Virginia
« on: April 26, 2010, 10:21:21 AM »
Does anyone have a part number or a location on where I can get the coned air filters that you can tape to the velocity stacks to make it look more radical. Any help woudl be appreciated. Thank you!!
Gryphon
Resistance is futile; if less than 1 ohm.
Fulton, MO
« Reply #1 on: April 26, 2010, 10:33:15 AM »
I got mine at the local O'Reilley's Auto Parts store.  They had to order them becausee they only had one in stock.  They are actually vent filters, but if you remove the rubber hose connection on the bottom, they go right on with body molding tape.
Cattman
Franklin, IN
« Reply #2 on: April 26, 2010, 10:33:37 AM »
Mine came from Autozone. Small engine air filter. Iff you want to get more radical stick some led's in them.
« Last Edit: April 26, 2010, 10:36:53 AM by Cattman » Logged
BIG COUNTRY 23321
Me & My Death Horse
« Reply #3 on: April 26, 2010, 11:43:57 AM »
Yes, I tottally agree with the radiacal LED setup and I am going to head that direction. what I am looking for is the specific part number of the vent filters or small engine air filter and location of where to get them. I have been researching them all over and not had much luck.
Cattman
Franklin, IN
« Reply #4 on: April 26, 2010, 01:15:43 PM »
Here's one, pull the rubber out of the bottom and you're good to go. Double faced trim tape or silicone.
http://www.autozone.com/autozone/catalog/accessories/accProductDetails.jsp?itemIdentifier=266500_0_0_&skuDescription=Spectre+/+Whiteclamp-oncottonfiberoilbreatherfilterelement-Maynotbelegalforuseonpollutioncontrolledvehicles&brandName=Spectre&displayName=Whiteclamp-oncottonfiberoilbreatherfilterelement-Maynotbelegalforuseonpollutioncontrolledvehicles&skuDisplayName=Spectre&categoryNValue=10099999&navValue=100997&categoryDisplayName=Whiteclamp-oncottonfiberoilbreatherfilterelement-Maynotbelegalforuseonpollutioncontrolledvehicles&parentId=00-10&itemId=997-10&productId=266500
NITRO
Eau Claire, WI
« Reply #5 on: April 26, 2010, 06:37:49 PM »
+1 on O'Reilly's. They're about $10 each and will have more at the store in about a day.
When in doubt, ride.
