July 15, 2025, 03:51:04 AM
Interstate Trunk on a Standard
Topic: Interstate Trunk on a Standard (Read 1407 times)
rmrc51
Palmyra, Virginia
April 28, 2010, 07:26:33 AM »
I have a 97 Standard which has been converted to a trike (MotorTrike kit). I'm considering trying to mount an IS trunk on her.
From other posts I've seen, I know I also need the IS side rails. Do any of you know if this is feasible for a standard trike and if so, where I might be able to find a good IS trunk with the required mounting rails?
VRCC # 30041
Joe Hummer
Arnold, MO
Re: Interstate Trunk on a Standard
April 28, 2010, 07:31:35 AM »
You can find them every once and a while on Ebay or Pinwalls. I believe you will only need the trunk, trunk rails and the fender rails. The IS fender rails have the bolts that hold the trunk on. Good luck on your search. Maybe one of our members that has SuperValked their bike would be willing to swap out fender rails with you.
Joe
1999 Valkyrie Interstate
PhredValk
Edmonton, Alberta, Canada
April 30, 2010, 11:55:05 PM »
I have an I/S, but if I didn't, I think I'd prefer the DB Black trunk from
http://www.mutazu.com/
VRCCDS0237
=> InZane XXV
