PhredValk
« on: April 30, 2010, 11:43:34 PM » |
Hi. New 99 I/S owner here (17k miles, cobras, green/silver, seems to go way too fast all the time). I've been riding for the last week, and having some trouble starting in the mornings. Just a few degrees above freezing (+2-+6 Celcius). I push the 'Choke' lever down, and sense no difference. Not a lot of resistance, and no change, once started, in how the engine runs. At first I thought maybe the cable wasn't attached to the choke linkage, but now see that it isn't a 'Choke' at all, but a "Start Enricher Circuit". Should I be looking for a cable that goes somewhere, or is this normal? And if I should look, where? The Clymer Guide has nothing on this device. Thanx in advance, Fred.
Hellcat
« Reply #1 on: May 01, 2010, 12:01:04 AM » |
Very common question here! You have to push it down HARD, you'll actually think you're going to break it off when you first do it right.
« Reply #2 on: May 01, 2010, 03:19:37 AM » |
To clarify what he said, push till you hit resistance and then push it another 1/2" further down. Till ya hit resistance is just a cable slack taker-up-er.
Now, instead of saying I hit the end, just go do it again and make sure you are doing it all the way.......
Thunderbolt
« Reply #3 on: May 01, 2010, 03:30:41 AM » |
like they said and don't touch the throttle, just choke all the way. Gradually take choke off as engine speed increases until it will run without it. Don't leave it on too long.
Disco
Republic of Texas
« Reply #4 on: May 01, 2010, 06:52:57 AM » |
Fred, my choke lever didn't seem to help with starting either until I opened the housing around the choke lever, lubed the lever/cable with white lithium grease, reassembled, and worked the lever back and forth to increase its travel. Only then did the lever move enough to actuate the cables. My lever moves almost 1/4 of the way around the bar.
2000 Bumblebee "Tourer", 98 Yellow & Cream Tourer, 97 Rescue blower bike 22 CRF450RL, 19 BMW R1250RT 78 CB550K 71 Suzuki MT50 Trailhopper .jpg) VRCC 27,916 IBA 44,783
Airetime
Anacortes, WA
« Reply #5 on: May 01, 2010, 06:54:15 AM » |
As others have said [/color]
PhredValk
« Reply #6 on: May 01, 2010, 06:10:47 PM » |
Just ran out and tried it. Really pushing hard it goes down another full inch! I'll see if it helps start the Big Girl tomorrow morning. Thanks, all. Fred.
TGViper
« Reply #7 on: May 01, 2010, 06:47:53 PM » |
You will be amazed at the difference. NO Throttle though....
mikeb
vrcc-29271
dansville mi by lansing mi
« Reply #8 on: May 02, 2010, 06:56:48 AM » |
welcome here glad to have ya
i dont care what you ride just ride mike & kari mivrcc capital city leader s.s.d.d.
PhredValk
« Reply #9 on: May 02, 2010, 09:55:49 AM » |
Started right up first try this morning with the choke pushed all the way down. Thanks again, Fred.
