Jeff K
« on: May 01, 2010, 06:04:45 AM » |
When I had my frame powder coated many years ago the vin tag was removed. I never gave it much thought. But now Florida wants to verify the vin before they will give me a registration. Surely the number is stamped somewhere on the frame? Even the motor block has changed since then. Am I screwed?
Jeff K
« Reply #1 on: May 01, 2010, 06:08:10 AM » |
Ah HA! it's on the neck where there is no hope of getting an easy read!
X Ring
VRCC #27389, VRCCDS #204
« Reply #2 on: May 01, 2010, 07:06:21 AM » |
See if you can get hold of a paint stick and rub across the stamping. Wipe off the excess and you'll be able to read the vin easily.
Marty
Dag
Country Rep. Norway
« Reply #3 on: May 01, 2010, 08:34:10 AM » |
Use a thin paper over and use a soft pencil. I have some old worn coins that are completely impossible to identify that I have identified the way. Maybe it works?
Psychotic Bovine
« Reply #4 on: May 01, 2010, 01:16:01 PM » |
get a digital camera, set it to macro, then take a picture of it. then you can read it on the lcd (where you can zoom in), or on your pc. I do this all of the time when trying to get serial numbers off of my tv or installed components.
"I aim to misbehave."
Jeff K
« Reply #5 on: May 01, 2010, 04:46:16 PM » |
The problem isn't with ME being able to read it. I have to have a LEO or someone from DMV read it. Most of it is visible, If I shine my dillo spotting light in there you can just make it out. The powder coat is pretty thick.
« Reply #6 on: May 01, 2010, 05:24:36 PM » |
Can you get a pick and scratch out the numbers?
Jeff K
« Reply #7 on: May 01, 2010, 06:51:22 PM » |
And ruin my paint job??  I think I can convince the LEO when he shows up. If he won't go with that I can rub a piece of 1000 grit over it to bring the numbers out.
Big IV
« Reply #8 on: May 03, 2010, 07:19:00 AM » |
Let us know how that turns out. Should be interesting.
"Ride Free Citizen!" VRCCDS0176
Jeff K
« Reply #9 on: May 03, 2010, 07:50:24 AM » |
Well, I got lucky. The LEO that showed up is a rider too. He has a Hyabusa he was telling me all about it. 106 in first gear... I wanted to tell him that was illegal...  But he took a quick glance at the illegible stamped in numbers and pretended to read them, then signed off on the paper.
stormrider
« Reply #10 on: May 03, 2010, 08:11:20 AM » |
Lucky or blessed? I'd go with blessed.
Big IV
« Reply #11 on: May 03, 2010, 08:14:30 AM » |
Well, I got lucky. The LEO that showed up is a rider too. He has a Hyabusa he was telling me all about it. 106 in first gear... I wanted to tell him that was illegal...  But he took a quick glance at the illegible stamped in numbers and pretended to read them, then signed off on the paper.  Sometimes it is good to know when not to argue.
