November 21, 2025, 04:41:11 AM
who has the best price on turn signal switch?
Topic: who has the best price on turn signal switch? (Read 1697 times)
laserpat
Cedar Park, Texas
May 02, 2010, 05:52:01 AM »
For a tourer. Honda sells fir $114. tia
Earl in Pensacola
Re: who has the best price on turn signal switch?
May 02, 2010, 05:56:32 AM »
I'd try "Pinwall". There is a 99% chance that they will have one and at about 25% of new OEM
May 02, 2010, 07:34:35 AM »
Don't buy a new one. Your problem is the old grease in it has gotten dry. Open the cover and remove the VERY small phillips screw holding down the thumb actuator. Spray/scrape out as much of the old grease and then spray a contact cleaner in the mechanism. Relube all the moving parts with a dielectric grease (Super Lube at ACE). Reassemble and your good for several more years.
laserpat
Cedar Park, Texas
May 02, 2010, 07:50:19 AM »
I've had the old one apart 3 times, cleaned and tensioned springs, lubed with dielectric grease. It works if I pull the plastic slider into the contacts but I think the contacts are worn out. I welcome any advice. Pat
May 02, 2010, 08:33:47 AM »
I cleaned mine this spring. sigs would take awhile to come on when it got below 40 deg out. Cleaned all the old grease out and used steal wool/sandpaper on the contacs. I may even pryed them up a little. Works better. Try and not to get everything super tight.
laserpat
Cedar Park, Texas
May 02, 2010, 02:36:54 PM »
I think I got it fixed. A pinpoint dot of dried grease was just enough to keep the contact open. Thanks for the input.
=> InZane XXV
