January 31, 2026, 02:47:58 AM *
Author Topic: Replacing Timing Belts  (Read 2501 times)
blackvalk
PARK CITY, UTAH
« on: May 07, 2010, 01:26:32 PM »
I'm surprised there isn't a post on the steps to remove and replace the timing belts. I'm also replacing the trigger wheel at the same time. I just want to make sure I don't slip a tooth on any of the sprockets. From what I've read, that would be disasterous.
Does someone have the process written down with all the safety stops in place?  I don't have a manual.
Bill
Daniel Meyer
The State of confusion.
« Reply #1 on: May 07, 2010, 01:59:42 PM »
Shoptalk is your friend.
http://valkyrieriders.com/shoptalk/joeswheel.htm
http://valkyrieriders.com/shoptalk/timingwheel.htm
http://valkyrieriders.com/shoptalk/carlbelts.htm
CUAgain,
Daniel Meyer
Valker
Wahoo!!!!
Texas Panhandle
« Reply #2 on: May 07, 2010, 02:13:55 PM »
Daniel, I had his same question. The Shoptalk article on the timing belts just says to look at the manual.
Daniel Meyer
« Reply #3 on: May 07, 2010, 02:21:18 PM »
To change the wheel, you have done everything needed to change the belts (the belts have to come off to change the wheel).
Check out sgt joes...article I linked.
All that said...you SHOULD have a manual if you dig this deep in these machines.
CUAgain,
Daniel Meyer
ricoman
Sarasota, FL
« Reply #4 on: May 07, 2010, 03:24:54 PM »
"(the belts have to come off to change the wheel)."
Only the right belt is removed to change the trigger wheel!
« Last Edit: May 07, 2010, 04:05:55 PM by ricoman » Logged
pat
Québec , Canada
« Reply #5 on: May 07, 2010, 05:54:03 PM »
Donwload the manual
Thanks to Dag Verpeide
http://www.valkyrienorway.com/1520manual/valkyriegl1500.zip
blackvalk
PARK CITY, UTAH
« Reply #6 on: May 07, 2010, 08:46:29 PM »
I printed the two pages out of the manual you  suggested. I think between the two pages and the posts on the trigger wheel replacement, I should be in good shape.
You are right about the manual, I would feel more comfortable having one, but, viewing it on the web was very helpful.
Thanks again,
Bill
Mr.BubblesVRCCDS0008
« Reply #7 on: May 08, 2010, 06:09:50 AM »
I did mine awhile back, I would suggest mark everything to make sure it doesn't move and pull the plugs and  use a socket and rachet to turn the engine over after finishing to make sure nothing is out of timing and no funny noises or binding. Not hard to do and you'll feel better when you start it  with the starter the first time. JMHO
V-SIX DS#121
Western NC
« Reply #8 on: May 08, 2010, 06:50:18 AM »
The best advice I can give from experience is BE CAREFUL.  I marked with red paint and got the right side off,equels warped valve.
