January 31, 2026, 02:47:38 AM *
Author Topic: rad hose "slinky" installation  (Read 1840 times)
CanadianViking
Calgary, Alberta Canada
« on: May 08, 2010, 07:54:13 AM »
I picked up a hose "slinky" from Valkyrie Bling (see http://www.valkyrieblingandmore.com/sthosl.html).
Can anyone describe the installation procedure?
assistance is much appreciated!
Cheers,
Thomas Hansen
"CanadianViking"
VRCC Member #30753
Gunslinger
Brian Huntzinger, EMT-P
Wamego, KS
« Reply #1 on: May 08, 2010, 11:30:58 AM »
Umm,
Place drain pan under hose (Top of it if ya want to minimize fluid lost, but you are going to dump the whole radiator)
Disconnect top of hose, Slide slinky on.
Remove set screw from radiator cap, Top off with 50/50 mix.
idle to open the thermostat and get any excess air out (although there shouldn't be any)
Recap and check for leaks.
Be careful with the radiator cap as it and the fill hole can be easily damaged on removal/reinstall.
Did I miss anything guy's?
VRCC#   26468
VRCCDS# 0228
"Some learn by listening, Others learn by watching...
The rest of us have to pee on the electric fence ourselves"
DFragn
« Reply #2 on: May 08, 2010, 01:14:39 PM »
Umm,
You could also rotate the slinky' first coil or two over the top clamp screw to hold it up high so it doesn't slouch if need be.
