January 31, 2026, 02:47:59 AM *
Author Topic: The Mystery Continues - All Help Welcome  (Read 2250 times)
valk2128
Suwanee, GA
« on: May 09, 2010, 01:58:00 PM »
I have a wobble that can be felt when rolling the Valkyrie down the driveway.
When I ride at  5 mph, I can feel it.
I have adjusted the steering stem ( 3 times).  The frontend feels tight and there is no binding.
It could be coming from the backend, I am not sure
There is a new set of Cobra's on her.
I had a new set of Dunlop's and went back and got the Cobras, so it should not be the tires.
Front wheel bearings  have been replaced.
I have changed the shock bushing also.
I have had the bike up on a lift and spun both tires, all seems fine.
Only 18,400 miles on my 1998 Valkyrie.
Any ideas sugestion are welcome.
If you are in or near Suwanee, GA area, you are more than welcome to stop by and take her for a ride.
I am just a bit frustrated.
Thanks for all the help you have all been.
« Last Edit: May 09, 2010, 02:06:59 PM by valk2128 » Logged
Brad
Reno, Nevada
« Reply #1 on: May 09, 2010, 02:04:39 PM »
Have you put it up on a jack or lift and give the front tire a spin and give it a look, also put it in gear and let it idle up in the air and looked over the rear tire?
junior
new hampshire
« Reply #2 on: May 09, 2010, 02:27:24 PM »
check your swingarm bearings
Valker
Wahoo!!!!
Texas Panhandle
« Reply #3 on: May 09, 2010, 02:40:45 PM »
At that low of a speed, I would suspect a tire that might not be fully seated on the rim, a tire with a bad belt, or a bent wheel.
2qmedic
Simply Awesome!!!
« Reply #4 on: May 09, 2010, 03:36:38 PM »
Did it appear all at once or gradually getting worse?
I mounted a front tire and it drove me nuts trying to balance it to ride smooth. I put the bike in the air, spun the tire and thought it was a out of round tire, but it was actually not correctly seated.
But with the 2nd set of tires, sounds like the tires may not be the issue.
Hope you find it soon.
« Last Edit: May 09, 2010, 04:07:44 PM by 2qmedic » Logged
fstsix
« Reply #5 on: May 09, 2010, 04:24:06 PM »
I had a Avon mounted on the rear years ago, i lifted the back tire off the ground with the lift and put a dial indicator on it, and it was out of round by almost a 1/2 inch, the dealer took it back, and when they put on the new tire i told them to check it for true or i wont be so friendly when i come back next time. Also just last summer had a new Non Motorcycle tire  Smiley  installed and it was moving side to side, i guess i have seen it all.
JimC
SE Wisconsin
« Reply #6 on: May 09, 2010, 08:13:11 PM »
You are a little vague about the tire situation.
Did it do the same thing with both the Dunlops and the Cobra's?
If not, I would suspect a bad tire.
Jim
Jim Callaghan    SE Wisconsin
