January 31, 2026, 05:50:04 AM *
Author Topic: Where can I buy the Left rear Wheel bearing # 6204RS?  (Read 3441 times)
dennis_obryan1965@msn.com
« on: May 09, 2010, 05:35:33 PM »
Found this on the shop talk generic parts page
Chili Pepper
Michigan
« Reply #1 on: May 09, 2010, 05:41:24 PM »
I would go here: http://www.hdlparts.com/default.asp
« Reply #2 on: May 09, 2010, 06:06:35 PM »
Got mine from a bearing store...........
Ball Bearings Inc. I think was the name of it.  It is a local bearing place however you should have a local store  in your town or close by at a bigger town.
X Ring
VRCC #27389, VRCCDS #204
« Reply #3 on: May 09, 2010, 06:09:28 PM »
I buy from Motion Industries but you can always order from HDL Parts or from the stealer.
Marty
Disco
Republic of Texas
« Reply #4 on: May 10, 2010, 04:01:21 AM »
NAPA has 6204 bearings, but did not show the other rear, 5204.  I got 3 6204 and 1 5204 at Purvis a month ago.
http://www.purvisindustries.com/locations.html
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
Mr.BubblesVRCCDS0008
« Reply #5 on: May 10, 2010, 07:35:42 PM »
Local bearing houses have them by the gross. Should be about 10 or 12 bucks.
F6Dave
« Reply #6 on: May 10, 2010, 07:51:55 PM »
I bought my replacement at NAPA, and got a backup at Pep Boys for about $12.
X Ring
« Reply #7 on: May 10, 2010, 10:13:16 PM »
That's what I paid for my SKFs
Marty
Tx Bohemian
Victoria, Tx
« Reply #8 on: May 11, 2010, 08:10:16 AM »
So do you bring the old bearing in for them to match it up or do you tell them the 6204,5204, etc... numbers?  Or what numbers?
Al
Madmike
Campbell River BC, Canada
« Reply #9 on: May 11, 2010, 08:43:36 AM »
If you take the old ones in they will measure them and match that way along with physical characteristics.
If you tell them the part # they may want to know if both sides are sealed.
Disco
Republic of Texas
« Reply #10 on: May 11, 2010, 09:29:10 AM »
All they (should) need is 5204 & 6204, sealed on both sides.
If that's not enough for them to be sure, the 5204 has an ID of 20mm, an OD of 47mm, and a Depth of 20.6mm.  The 6204 has an ID of 20mm, an OD of 47mm, and a Depth of 14mm.
78 CB550K
Tx Bohemian
Victoria, Tx
« Reply #11 on: May 24, 2010, 08:04:11 AM »
Ok, I called the local Motion Industries and the guy I talked to knew what bearings I needed by giving him the 6204, 5204 #s.  (I take it he musta been a Harley rider cause when I mentioned they went on a Honda he said they were probably crap from the factory!!  I had limited time so I didn't want to argue...) He said something like $12-15 as compared to HLD.com which they are around $45-50.
I'm going to replace my front bearings too.
Does anyone know what these bearing numbers are?
What about seals?  Are there any to be replaced when replacing bearings and if so would a place like Motion Industries have these?  (If I'd want to put up with the Harley guy)
Al
X Ring
« Reply #12 on: May 24, 2010, 09:43:50 AM »
From 98 on the front wheel bearings are the same as the left rear, 6204-2RS.  The 97s used 6004-2RS.
Marty
MP
North Dakota
« Reply #13 on: May 24, 2010, 11:42:45 AM »
$16.65 for the left wheel bearing from HDL, not the $45-50 quoted.
MP
"Ridin' with Cycho"
Tx Bohemian
Victoria, Tx
« Reply #14 on: May 25, 2010, 05:40:37 AM »
MP
Your correct, it's the right bearing that's $45 at HDL.
Al
John U.
Southern Delaware
« Reply #15 on: May 25, 2010, 06:04:35 PM »
Marty
I checked out MotionIndustries.com and they have a bunch of 6204 2RS bearings. Almost all of them have additional alpha-numeric designations.
Marty, what bearings are you using? I read where you mentioned SKF but there are 18 varieities of SKF 6204 2RS bearings listed. In my research I've heard that 6204VV are a high performance bearing, I think. These size and type bearungs are used in a wide variety of applications. So I want to avoid buying a bearing that is intended for an electric motor or food processing machine.
There are 6 different 6204VV bearings listed with no indication of the reccommended application.
Anyway, I'm confused. Any help would be appreciated.
John
Tx Bohemian
Victoria, Tx
« Reply #16 on: May 26, 2010, 05:29:31 AM »
Marty
John
Wow!  That is a good question.
All the guy said that I talked to at Motion Industries was that some 6204 bearings had a "RS" at the end that stood for rubber seal.  He never mentioned anything else except that a SKF brand was the best, at least in his opinion.
Al
