January 31, 2026, 04:21:54 AM *
Author Topic: Having Trouble gettin New Altenator Back In  (Read 2356 times)
Maldog
Woodstock IL
« on: May 09, 2010, 07:13:25 PM »
Hay Guys My Friend John and I could not get the blades on the new altinator to fit back in thr rubber dampiners,those who have done this know what im refering to lol and John is a motorcycle Mech retired so is there some sort of incantation we are supposed to repeat as we reinsert the new altinator  or if theresa lil trick any one can tell us about we would be forever greatful we got close but it just didnt want to go all the way in .Im sure we are missin something simple so any suggestioins would be appreciated for sure Thanks in advance Mal Embarrassed
« Reply #1 on: May 09, 2010, 07:20:33 PM »
WD-40 is your friend  cooldude
Maldog
Woodstock IL
« Reply #2 on: May 09, 2010, 07:29:22 PM »
yes it is  lol John and I discussed using KY Jelly on the fins when we try it again coolsmiley
Misfit
Colorado Springs Colorado
« Reply #3 on: May 09, 2010, 07:33:21 PM »
Ya gotta hold your mouth just right and it will slide right in. Grin
« Reply #4 on: May 09, 2010, 11:21:05 PM »
Also, if ya blink just right it will fall in also.
I was fighting my 1st one I replaced and was getting madder by the minute.
Was ready to start spewing nasties, when my youngest then grand daughter walked in the garage.   She tripped on my light cord, I looked at her and the SOB dropped right in.      To this day, I still don't know what I was doing wrong...
Gunslinger
Brian Huntzinger, EMT-P
Wamego, KS
« Reply #5 on: May 10, 2010, 07:30:18 AM »
The biggest key is getting the alternator square with the hole, the second thing is making sure that all four rubber bumpers are in their correct position. I have found it easiest when they sit at 12:00 3:00 6:00 and 9:00. then the only one that really moves around much it the top one (12:00) Get in there with a small screw driver or pick and lift it up until the fins are started then it should be a piece of cake.
VRCC#   26468
VRCCDS# 0228
"Some learn by listening, Others learn by watching...
The rest of us have to pee on the electric fence ourselves"
Rocketman
Seabrook, Texas
« Reply #6 on: May 10, 2010, 07:55:40 AM »
Check your dampers.  There are four of them, but each one is two pads, connected by a small rubber "strap".  Reach in and pull one out, and you'll see what I mean.
Those straps are only there to keep the dampers in place during alternator installation.  If that strap is broken, then the campers will not behave.  There's no way to reach in and move the dampers around while installing the alternator.  If you have one with the strap broken, put it at the bottom (6 o'clock) position.  Gravity will hold it in place.  If you have two, you might have to replace one or both in order to get it in.  The only other way (if that's the issue) is to pay attention to which way gravity wants to pull it, and work the alternator vanes around to manipulate the dampers in the blind.
Mark
Gunslinger
Wamego, KS
« Reply #7 on: May 10, 2010, 08:09:24 AM »
Mark
Interesting, a few weeks ago I pulled the alternator from my new standard and installed it in my IS as a spare until the new alternator came in. Yesterday I pulled that one back out of my IS and reinstalled it into the standard and installed the new alternator in the IS. By my count that would be three installs. I used a small pick each time to adjust the bumper (Dampers) slightly until I had all four fins Just barely started, then slid the alternator home and tightened it up.
I'm not real happy about this bit of experience, but I can now pull an alternator and install a new one in about 25 minutes.
VRCC#   26468
VRCCDS# 0228
Rocketman
Seabrook, Texas
« Reply #8 on: May 10, 2010, 08:19:48 AM »
Mark
Wow.  I didn't think there was room to squeeze anything in there.  I stand corrected.
As for the "not happy about the experience", I second, third, etc. that one.  I did TOO MANY alternator swaps a year or so ago.  I got pretty good at it, but I'd rather not have any experience on it at all.
Mr.BubblesVRCCDS0008
« Reply #9 on: May 11, 2010, 03:49:39 PM »
A small dab of grease will help hold the dampers in place. I always leave the noise suppressor off until alt. is in and then bolt it on.
Maldog
Woodstock IL
« Reply #10 on: May 15, 2010, 06:10:42 PM »
I just wanna say thanks for all the tips,suggestions and humor shared,by all  u guys well we used every one of ur sugestions and the I/S is a runnin again with new plugs and oil also Thanks to all of u wahoooo now I can take her to the dealership and have my new avon cobras installed Thanks again guys and God Bless,Mal coolsmiley
