June 22, 2025, 02:52:08 AM *
Author Topic: Whistling sound through IS wind shield vent  (Read 3413 times)
petevenne
Concord NH
« on: March 15, 2009, 04:41:06 PM »
Have a stange whistling sound through my Interstate fairing wind shield vent.. Putting my hand over vent makes sound go away.. Any cause or cure ?? No, the turning up the radio doesn't help...
Pete Venne
99 Interstate Black & Red
Concord NH 03303
3W-lonerider
Shippensburg Pa
« Reply #1 on: March 15, 2009, 04:46:04 PM »
what i done was go to lowe's hardware or any hardware store would have this.. get a peice of pipe insulation. the kind that is split and slips over the pipe. i think i used 3/4 inch..cut it to the lenth ya need and shove it up inside the front. serves 2 perposes. noise goes away. and also when ya get caught in a rain storm ..no more water coming threw there getting on the inside of your winshield.   cooldude
Master Blaster
Deridder, Louisiana
« Reply #2 on: March 15, 2009, 06:25:08 PM »
Also keeps bug parts on the outside.
Shockbushing Gary
« Reply #3 on: March 15, 2009, 08:06:18 PM »
The actual problem is this:
If you look up inside the vent, you will see 2 pieces that constitute the duct. They overlap, and as wind pases over them, make a reed. So you get a whistle.
All the fixes offered address this. What I did was get some black electrical tape and cover the joint in the duct. That stopped the whistle. Then, to slow the bugs and rain, I folded up some furnace filter material and stuffed it in the duct. It hid in there pretty well. It also let the breeze thru but not the bugs and very little of the rain.
« Reply #4 on: March 16, 2009, 03:54:25 AM »
Yeah, I keep mine plugged with a piece of black foam rubber.  The only time I take it out is for the hottest days of the year.
PushStart
Black '99 InterState
Story City, Iowa
« Reply #5 on: March 17, 2009, 12:43:17 PM »
I took my faring apart this winter and reassembled it using foam strip insulation between the windshield and faring.  I also duct taped the seams in the vent assembly.  One or the other took care of the whistle.
petevenne
Concord NH
« Reply #6 on: March 18, 2009, 06:20:04 PM »
Thanks All!!! That did it.. A 4 inch piece of aluminum tape across the seam did the job.. Just need to make a But Plug for the vent for bad weather..
Pete
Concord NH..
« Reply #7 on: March 19, 2009, 05:49:41 AM »
Just need to make a Butt Plug for the vent for bad weather
Here you go.  (apologies in advance)
http://en.wikipedia.org/wiki/Butt_plug
Momz
ABATE, AMA, & MRF rep.
« Reply #8 on: March 21, 2009, 02:03:46 PM »
What tune is it whistling?
Dixie,...Camptown ladies,...Battle Hymn o' the Republic? Cheesy
ALWAYS QUESTION AUTHORITY!
petevenne
Concord NH
« Reply #9 on: March 21, 2009, 03:59:29 PM »
Mine plays "Bad to the Bone" by George Thorogood over and over again...
