January 31, 2026, 02:48:02 AM *
Author Topic: Interstate carb spring install?  (Read 2019 times)
Farther
Quimper Peninsula, WA
« on: May 11, 2010, 08:53:41 AM »
I just installed the Interstate carb springs in my '03 Standard.  After I got everything back together I started to wonder if I should have used anit-seize on the cover screws.  For those with mechanical skills, should aniti-seize be used for the carb cover screws?
~Farther
« Reply #1 on: May 11, 2010, 09:24:19 AM »
You should use an anti-seize on all carburetor fasteners.
Same with anything that bolts into aluminum threaded holes with a few exceptions.
Jack B
Two Rivers Wis
« Reply #2 on: May 11, 2010, 04:31:57 PM »
Can you tell the diff with the I/S spring??
Let’s RIDE
Farther
« Reply #3 on: May 11, 2010, 04:51:37 PM »
The power was rolling on slightly more smoothly.  Probably a placebo effect.
~Farther
ricoman
Sarasota, FL
« Reply #4 on: May 12, 2010, 03:03:48 AM »
"placebo" effect
isn't he one of those famous tenors?
Farther
« Reply #5 on: May 12, 2010, 07:02:50 AM »
Ya, Placebo Damingo!
~Farther
