January 31, 2026, 02:48:29 AM
interstate windsheild replacement
Topic: interstate windsheild replacement (Read 2393 times)
bigolguy
May 11, 2010, 04:53:40 PM »
Hello, I recieved a new windsheild today and need help on how to take the old one off. thank-you
shortleg
maryland
Re: interstate windsheild replacement
May 11, 2010, 05:25:11 PM »
First thing ,remove the speaker panels.
Then look inside you will see screws that hold the
chrome molding at bottom of windshield.
Remove them then the chrome and you will see the
screws that hold the windsheild.
Get a good flashlight and you will see what I mean.
Shortleg[Dave]
Mr.BubblesVRCCDS0008
May 11, 2010, 06:33:55 PM »
Also when installing the new one use caution tightening the four bolts I cracked my new one. Luckily it went down not up and has no ran since installing.
PAVALKER
Pittsburgh, Pa
May 11, 2010, 06:35:43 PM »
If you would like a copy of the Service Manual to help you with the windshield and other maintenance/repairs..... click here.
http://www.valkyrienorway.com/1520manual/valkyriegl1500.zip
John
roboto65
Conroe,TX
May 11, 2010, 06:58:07 PM »
Did you have the metal spacers in there just asking because when I tighten mine it hits that and kinda stops the bolt from tightening anymore .
Allen Rugg
VRCC #30806
1978 Kawasaki KZ 650 project
May 11, 2010, 08:12:44 PM »
Yes I had the metal spacers, I think I might have had the windshield in a bind or not quite in the right position. Surprised the h@## out of me too.
MP
North Dakota
Reply #6 on:
May 12, 2010, 05:00:29 AM »
If it cracked with the metal inserts, one of the holes must not have been lined up right. Otherwise, there would not be much pressure on the windshield.
MP
"Ridin' with Cycho"
1FAST6
Sanford, NC
Reply #7 on:
May 12, 2010, 06:37:12 AM »
Just like Shortleg said. Only takes a few minutes, assuming the screws come out without having the inserts spinning inside the fairing. Let us know if the screws don't come out. You can also search Archive for "pem nut"
bigolguy
Reply #8 on:
May 13, 2010, 09:19:41 AM »
Thank-you to all for the info . I put the new windsheild in last night, the help is appreciated.
Dave
