January 31, 2026, 04:21:33 AM *
Author Topic: Order 2 rear tires for the front  (Read 3640 times)
Warlock
Magnolia, Ms
« on: May 11, 2010, 10:38:02 PM »
Ordered 2 130/90/17 Avons from Jake Wilson. Good price. Delivered to the house for $150.00 for both tires. Got $10.00 off for ordering 2 tires and entered the code that Marty posted cc20 and got $20.00 off and free shipping. Best price I have found on tires. Started to do 2 different orders but would not get the $10.00 off and would have to pay $7.00 on each order being they were under $99.00 dollars.
David
Rio Wil
« Reply #1 on: May 11, 2010, 10:45:18 PM »
Dang.....both tires for $150?
Sale still going on?
stormrider
Kinsey, AL
« Reply #2 on: May 12, 2010, 05:19:10 AM »
Got any contact info. I need a new front. And which Avon's are they?
Steve
Warlock
Magnolia, Ms
« Reply #3 on: May 12, 2010, 06:02:53 AM »
Here's the web site. When you check out they will take 10 dollars off for ordering two tires. Then there is a place to put the code in which is cc20 and check out. My total was $149.98 delivered.
http://www.jakewilson.com/productDetail.do?navTitle=Motorcycle+Tire+Accessories&webCatId=38&navType=type&webTypeId=320&prodFamilyId=22938&listingId=&sizeAttr=5464
David
DFragn
« Reply #4 on: May 12, 2010, 09:14:04 AM »
David
Those appear to be Bias Ply - yes?
Warlock
Magnolia, Ms
« Reply #5 on: May 12, 2010, 10:18:09 AM »
Should be. They call it a 130/90/17, but when you look at the spec at Avon the say it's a 140 wide.
David
« Reply #6 on: May 12, 2010, 02:04:36 PM »
David
that's a V-rated tire. will most likely wear faster due to the compound.  at colder temps or when first riding the tire will be more slippery than an H-rated until it warms up.
a v-rated on front and h-rated on back could cause handling problems.
Something to be aware of. cooldude
Warlock
Magnolia, Ms
« Reply #7 on: May 12, 2010, 02:34:17 PM »
David
I run a V rated darkside on the back. Also running a V rated at present on the front. My present Cobra has a 4.7 thread depth when new and the new one is 7.5. Will see how it does when mounted. Might be good and might be a nightmare. Will be later this year before mounting it. Got it ahead of time with the deal.
David
X Ring
VRCC #27389, VRCCDS #204
« Reply #8 on: May 12, 2010, 02:40:37 PM »
I could have sworn speed ratings deal with the ability of the tire to deal with the heat of high speed operation not traction.  That's a separate rating.  If it was as CA states, Metzler could end up being in a whole lot of trouble as they spec a V rated tire for the front and a H rated tire for the back.
Marty
« Reply #9 on: May 12, 2010, 02:44:17 PM »
David
David
just noticed u got the mississippi heat, u might never notice cold tires. Smiley
magnolia, is that next to pascagoula?
Warlock
Magnolia, Ms
« Reply #10 on: May 12, 2010, 02:48:49 PM »
David
David
Not too far as the crow fly's. Kinda NW of there.
David
« Reply #11 on: May 12, 2010, 02:49:56 PM »
Marty
my experience is when a v-rated tire is ridden in the low 40 degree F range, a little slippery until it warms up. this was on a GS1200 Bandit that I had. google searches will show that different rated tires react differently to temps. some info states that a v-rated tires will actually get better wear than a h-rated in the 90-100 degree range.
the info is out, some of it is hard to find though.
Warlock
Magnolia, Ms
« Reply #12 on: May 12, 2010, 02:51:16 PM »
Marty
Went back and read your Avon post on Jake Wilson store and the coupon. Looks like the place to buy tires even without the coupon.
David
« Reply #13 on: May 12, 2010, 03:53:21 PM »
Marty
David
Wonder if they suck ? I don't see them sticking that good in my minds eye  Undecided What about makin' the bike(s) lower ? I thought about it however that deal of making my bike lower just does'nt appeal to me I've hit my engine guards in curves as it is  Undecided  Good luck David at least you jumped in with both feet buying two  Wink
Warlock
Magnolia, Ms
« Reply #14 on: May 12, 2010, 04:56:39 PM »
Marty
David
I hope the don't suck and hope they stick. Looked up specs on both tires. The with of the regular Cobra is 5.9 and the one I'm getting is 5.5. Total height of the Cobra 150/80/17 is 26.5 and the total height of the 130/90/17 is 26.4. Not much difference at all. That's why I decided against the 150/70/17. Nothing wrong with the 150/70/17, I didn't want my speedometer to read more off than it is now. The Avon is a good looking tire. With this tire it is only 0.0039 shorter. Also lot more beef. Stock tire 4.7 mm thread depth and this one 7.5 mm thread depth. Once I run them a bit I'll have to give a report on them.
David
X Ring
« Reply #15 on: May 12, 2010, 05:01:07 PM »
Hell Joe, there's pics of you in a curve that you could have used feeler gauges between the engine guard and the road.   cooldude
Marty
X Ring
« Reply #16 on: May 12, 2010, 05:07:42 PM »
David
David
He's off I-55 near McComb.  I'm off US 98 about an hour north of Pascagoula.  In fact I moved from there to Lucedale in May last year.
Martu
stormrider
Kinsey, AL
« Reply #17 on: May 12, 2010, 05:46:30 PM »
Marty
David
Joe, meant to look see what you run while at Cheaha. So, what do you run up front. Been running an Avon Cobra and before that a Dulop E3. The Avon's done well and seems to have good grip in wet or dry.
« Reply #18 on: May 12, 2010, 05:54:33 PM »
Marty
David
David
Please do get back with that report David I've seen you ride and we share a close style.I look forward to seeing what you think about these tires.
« Reply #19 on: May 12, 2010, 05:55:32 PM »
Marty
David
Up front Avon Cobra
Warlock
Magnolia, Ms
« Reply #20 on: May 12, 2010, 06:00:56 PM »
Marty
David
David
Will do. I'll post a picture of them when they come in. I like the way these Avon's look. If they stick anything like the Cobra's I'll be tickled.
David
« Reply #21 on: May 13, 2010, 05:31:03 AM »
[/quote]
[/quote]Not too far as the crow fly's. Kinda NW of there.
David
[/quote]
there is a best western called "best western magnolia" west of pasca on rt 90, thought it was magnolia but just looked it up, it is still the town of Gautier.
X Ring
« Reply #22 on: May 13, 2010, 08:48:01 AM »
I lived in Pascagoula before Hurricane Katrina then moved to Gautier afterward.  What were you doing in the shipbuilding capital of the south?  I know where that hotel is, used to pass it on the way to and coming from work.
Marty
« Reply #23 on: May 13, 2010, 10:11:27 AM »
Marty
I've been coming down there for the past 19 yrs. Have stayed in moss point, pascagoula, ocean springs, gulfport, and biloxi. I inspect the environmental system installations on new ship contruction at Ingalls which is now northrop grumman.
they tell me I'm just a yankee and not a damm yankee.  Grin
X Ring
« Reply #24 on: May 13, 2010, 12:45:46 PM »
That's true.  You didn't stay.  We've probably met there.
Marty
stormrider
Kinsey, AL
« Reply #25 on: May 14, 2010, 12:34:51 PM »
Hey Joe, thanks for the reply. I think I asked, or at least was gonna ask what you are running up front. Fixin to order a new Cobra.
stormrider
Kinsey, AL
« Reply #26 on: May 14, 2010, 09:08:34 PM »
Thanks for the info and link to Jake Wilson. Ordered an Avon Cobra for the front. Best price anywhere and added a little chrome to make it over $150 for an extra $20 back plus will get a $25 mail in rebate from Avon and free shipping. That should make a $200+ tire about $103. Thanks for the post and link and the code, etc. Got some new rubber on the way. BTW, I placed the order and within 5 minutes a lady calls from Jake Wilson, seems the p clamps I ordered will be available by next Friday. She wanted to know if I wanted them to go ahead and ship the tire. Wow, talk about service. I'm talking less than 5 minutes. That's great customer service anyway you look at it.
Warlock
Magnolia, Ms
« Reply #27 on: May 14, 2010, 09:35:59 PM »
Marty (X-Ring) had posted a while back with the website and the code. They do have good prices and will be using unless I find someone else to beat their prices.
David
