January 31, 2026, 07:32:13 AM *
Author Topic: Progressive shock question  (Read 2023 times)
ridgeman06
Palmer, MA
« on: May 13, 2010, 03:53:20 AM »
Hi Guys,
I have a 98 tourer that is in excellent condition. I bought it used from a dealer and it has a set of Progressive 416 air shocks installed.
I am not sure the difference between the different models, or why this particular one is on my bike. I have had the bike for three years now with no problems.
This winter I removed them to do a tire change. When I laid them down on my bench, a teaspoon of oil came out of the airtube connection on one of them. I didn't realize that this could happen. I must of set it down with the airtube connection pointing down.
Does this indicate that something is wrong with the shock or is this something that can happen if you put it in this position? And, should I replace the little bit of oil that came out?
Thanks, Eric
1998 Maroon and Creme Tourer. This is my second Valkyrie. I have been a member here since I had bought my first one back in 1998. I had a different account then.
Gryphon
Resistance is futile; if less than 1 ohm.
Fulton, MO
« Reply #1 on: May 13, 2010, 05:48:57 AM »
You just laid the shock down with the port lower than the body of the shock.  Not a problem.  The shocks are air with oil dampening.  The teaspoon of oil shouldn't be enough to cause you  any problems, but try not to lose any more.
Gunslinger
Brian Huntzinger, EMT-P
Wamego, KS
« Reply #2 on: May 13, 2010, 11:48:44 PM »
Back on the topic of these. It is reasonable to try and rebuild a set of these yourself?
I have a set that needs work, Talked to Progressive and they happily told me they would rebuild / repair them for $35 - $260 depending on the issue.  Roll Eyes
Is there a manual or documentation out there somewhere that explains how these are built, and what parts are replaceable?
VRCC#   26468
VRCCDS# 0228
"Some learn by listening, Others learn by watching...
The rest of us have to pee on the electric fence ourselves"
Colin
My old job
Orba, Spain
« Reply #3 on: May 14, 2010, 03:37:41 AM »
Gunslinger on Progressives site there is a pdf with full instructions on how to do it yourself. If you can't find it drop me a PM I have it downloaded on my PC and I can email it to you.
Colin
VRCC Espana
My Bumble Bee re-build
ridgeman06
Palmer, MA
« Reply #4 on: May 14, 2010, 03:59:54 AM »
I guess I need not worry, Eric
