TGViper
« on: May 13, 2010, 02:24:11 PM » |
Ok - this site has been a huge help so far! Thanks so much...
When I bought the bike it had EBC pads with OEM rotors and buzzed like crazy. I ordered OEM pads, front and back and replaced today. Cleaned up both front calipers and re-installed. Did not take caliper off of back but pads went on just fine.
My question is: How much brake drag is normal for floating calipers?
I hear the fronts all the time, more so when the brake is applied obviously, then after releasing the brake, it gradually goes away, but never all the way away.
Is this normal?
TGViper
Saphire
Riding Pikes Peak July 2015
SW Indiana
« Reply #1 on: May 13, 2010, 04:54:11 PM » |
I'm curious to hear what the masters have to say about this......
I'm finally at 10K miles on the 97 Standard and starting to get some brake drag on the front as well and I think this is way too early to be looking at brakes and possibly rotors....
Any advice??
**Riding one IN a million, not one OF a million**
Misfit
« Reply #2 on: May 13, 2010, 04:56:06 PM » |
Pull the pins that they ride on and lube them. If they are lubed and everything is aligned properly there will be little drag.
TGViper
« Reply #3 on: May 13, 2010, 07:23:11 PM » |
What should the lube be for this?
Mr. Nuts
« Reply #4 on: May 13, 2010, 07:29:09 PM » |
What should the lube be for this? The pads are so easy to change I forgot that these are floating calipers. And they don't float very well without lube, or with old gunked up lube. Every auto store sells this as its used on all disk brake systems. Usually 99 cents or so for little packets sufficient for one job. Better to buy a little tube of it for $3 or so. Immediately fixed my problems...
“Speed has never killed anyone.... Suddenly becoming stationary, thats what gets you.” - Jeremy Clarkson
Oldswimr
« Reply #5 on: May 13, 2010, 08:53:40 PM » |
too weird, I just changed mine tonight, noticed the same from the front. Also did not lube the pins. Will pick some lube up tomorrow.
"Yes, it's fast, no you can't ride it.."
TGViper
« Reply #6 on: May 13, 2010, 09:05:49 PM » |
Sounds like I have a trip planned for NAPA tomorrow...
« Reply #7 on: May 14, 2010, 03:48:40 AM » |
Here's what one brand of the right goo looks like:  Don't forget to clean (but of course not lube) the pin the pads ride on:  -Mike
Oldswimr
« Reply #8 on: May 14, 2010, 07:25:11 AM » |
"Don't forget to clean (but of course not lube) the pin the pads ride on:"
So we DON"T lube the pins??
« Reply #9 on: May 14, 2010, 07:40:51 AM » |
the caliper "floats" on a couple of lubed pins that have rubber booties on them. The pads kind-of-slide on a pin, the one in the picture. Don't lube your brake pads  . It all becomes real clear when you're holding your caliper in your hand. If you don't clean the pad-pin when you change pads, the new fat pads will be trying to slide on a dirty-formerly-exposed part of the pad-pin and drag more than normal for a while... -Mike
« Last Edit: May 14, 2010, 07:43:15 AM by hubcapsc »
FryeVRCCDS0067
« Reply #10 on: May 14, 2010, 08:18:12 PM » |
If the brake fluid had been changed or “topped off” with worn pads the reservoir can be too full to allow the cylinders to fully retract when thicker new pads are installed. This can make them drag, wear quickly and overheat.
"Extremism in the defense of liberty is no vice. And... moderation in the pursuit of justice is no virtue.'' -- Barry Goldwater, Acceptance Speech at the Republican Convention; 1964
daytona
« Reply #11 on: May 15, 2010, 06:50:51 PM » |
+1 on that! Or there is crud behind the puck. Lube on pins can help but crud and or corrosion on pucks is more likely the culprit.
Just started!
TGViper
« Reply #12 on: May 15, 2010, 06:59:49 PM » |
+1 on that! Or there is crud behind the puck. Lube on pins can help but crud and or corrosion on pucks is more likely the culprit. "puck" is a new term today for me.. Is this the rubber booted part on the caliper by chance? Looks like the caliper can slide on this?
1FAST6
« Reply #13 on: May 15, 2010, 08:14:15 PM » |
I always check mine after installing pads and pumping up the brake, but before I let it off the jack. They always drag enough to make some noise, but not enough to prevent the wheel from spinning freely. If it won't complete one rotation after I give her a spin, then something's wrong. Not very scientific, but after 110k mi. I seems to be working for me... As for the noise, cut the piggies and you'll never hear them!
daytona
« Reply #14 on: May 16, 2010, 05:55:48 PM » |
+1 on that! Or there is crud behind the puck. Lube on pins can help but crud and or corrosion on pucks is more likely the culprit. "puck" is a new term today for me.. Is this the rubber booted part on the caliper by chance? Looks like the caliper can slide on this? Puck = The piston the B fluid pushes on to apply the pads to rotors. If they cant be pushed in by hand they are being bound by crud or corrosion. Must be popped out, cleaned and rubber seal should be replaced but just a cleaning may do the trick!
Just started!
« Reply #15 on: May 16, 2010, 06:03:50 PM » |
Here's a picture after I cleaned one of my calipers till it was spotless, and then popped the "pucks" out a little bit... see the crud that would have been pushed back in the caliper if I hadn't popped the pistons out... I popped them all the way out and cleaned them up...  -Mike
