January 31, 2026, 04:21:52 AM *
Author Topic: Does anyone know the size of the Rear Axle NUT, 1 1/6 inch socket is too small  (Read 3322 times)
valk2128
Suwanee, GA
« on: May 15, 2010, 12:06:31 PM »
What is the size of the rear axle nut?
« Last Edit: May 15, 2010, 12:23:20 PM by valk2128 » Logged
Valker
Wahoo!!!!
Texas Panhandle
« Reply #1 on: May 15, 2010, 12:18:04 PM »
1 1/16 inch socket fits perfectly. Not sure of the mm size.
valk2128
Suwanee, GA
« Reply #2 on: May 15, 2010, 12:22:02 PM »
My 1 1/16 socket is too small.  Anyone know the metric size?
NiteRiderF6
Doug n Stacy
Mississippi
« Reply #3 on: May 15, 2010, 01:36:14 PM »
That's a 22 mm nut
valk2128
Suwanee, GA
« Reply #4 on: May 15, 2010, 02:17:24 PM »
A 1 1/6 inch is too small and a 30 MM is too large.
So I am guessing that it is a 28 MM.
I am running out to buy a set of larger MM sockets, I will post the results later.
valk2001
There is nothing like riding a Fat Girl....
Darlington, SC
« Reply #5 on: May 15, 2010, 02:42:09 PM »
As mentioned in an earlier post, a 1 1/16" fits perfectly.
wizard -vrccds#125
Hitchcock Tx.
« Reply #6 on: May 15, 2010, 02:47:57 PM »
                             27 MM
valk2128
Suwanee, GA
« Reply #7 on: May 15, 2010, 04:14:03 PM »
Interesting that there are some many varied response, do the Valkyries vary that much by year, and model.
Mine is a 1998 Standard and the axle nut is 27 MM.
Thanks for all the responses.
« Reply #8 on: May 15, 2010, 04:38:52 PM »
27mm is correct.
A 1 1/16 should actually be a better fit, but you may need a 12-point rather than a 6-point socket.
