November 21, 2025, 06:41:57 AM *
Author Topic: brakeaway cruise installation help  (Read 2075 times)
loafer
« on: May 16, 2010, 01:15:35 PM »
Hi,
I'm halfway installed and the final hookups to the brake lever switch are not lining up too well.  The brake lever is hitting the main part of the asssembly when you apply them  It all seems a little too tight.  Any advice?
NITRO
Eau Claire, WI
« Reply #1 on: May 16, 2010, 04:32:24 PM »
Do you have stock levers? Mine worked great until I switched to the wider Kuryakyn levers, then the levers started hitting the main assembly like you're getting.
When in doubt, ride.
loafer
« Reply #2 on: May 17, 2010, 10:27:38 AM »
I am not sure, they were on the bike when i bought it.  I always assumed they were stock.
DFragn
« Reply #3 on: May 17, 2010, 11:23:10 AM »
Why not just add a washer where the slotted [Breakaway] angle mount secures to the lever pivot bolt. If your bottomed at the slot and still need the unit to roll forward increasing lever action clearance this should work.
I have true cruise control but I recently installed the Breakaway throttle lock on Joanne' VStar. I assume the mounting procedure is similar. I like the Breakaway and think it's the finest throttle lock available. It just takes some time [tinkering] for final function adjustments.
Airetime
Anacortes, WA
« Reply #4 on: May 17, 2010, 09:20:52 PM »
If the brake handle has a numbered disk for adjustment it is not the Valkyrie OE handle.
loafer
« Reply #5 on: May 18, 2010, 12:30:06 PM »
No Adjustment on the lever, so probably stock.  I got it to clear the mechanism, but now the throttle does not return too well when I start to tighten things up.  I may try starting over to be sure I have everything square.  thanks for the help so far
Garland
#618
Hendersonville NC
« Reply #6 on: May 19, 2010, 07:19:22 AM »
I took me several tries over a period of several weeks to get it perfect on mine. It is beautifully engineered, but everything needs to be just so.
loafer
« Reply #7 on: May 19, 2010, 07:24:22 AM »
I think I finally got it, a lot of adjustments, whew.
Thanks, for the help
Old Geezer Richard
San Antonio , Tx
« Reply #8 on: May 19, 2010, 08:09:30 AM »
Hey Loafer , I put one my Valk too and it beats the hell out of the old plastic cruise control , but you just need to tinker and adjust it little by little until the mechanics of this control works like it suppose too ... just take your time and work on the old patience patience and it will come to ya  uglystupid2 you would think for the price this thing oughta talk to me and make coffee too  2funny
Black Eagle
Wisconsin
« Reply #9 on: May 21, 2010, 08:28:59 AM »
I put one on a little over a year ago and everything lined up properly until I tightened up the fasteners and then it would bind.  What I found to be the "L" shaped bracket that (I think) fastened to the brake lever.  An ever so slightly movement when tightening the nut caused the alignment to get off and cause the binding.
My Suggestion, start here by moving it while still quite tight and see if that is the problem.
Good luck, when right the breakaway is great.
Dan
NITRO
Eau Claire, WI
« Reply #10 on: May 21, 2010, 08:35:55 PM »
I had a brakeaway on my STandard with the OEM grips. I now have an IS with Kury grips and am wondering if the lock will work with these? I have been told that it will and that it won't, so am curious about everyone else's experience.
