January 31, 2026, 04:21:34 AM *
Author Topic: Hiway Pegs  (Read 1920 times)
blackvalk
PARK CITY, UTAH
« on: May 17, 2010, 11:55:09 AM »
I currently have highway pegs mounted on my engine guards. My problem is the clamp doesn’t hold tight enough so the pegs rotate away from my feet.
My question is, what can I wrap around the bar increasing the diameter so the clamp has more of a bite. I thought about tape, sand paper and a strip of rubber. I haven’t tried anything yet.
Any suggestions?
« Reply #1 on: May 17, 2010, 12:15:59 PM »
I have 1 1/8" Kury P Clamps. They too rotate when pressure is applied. I cut a thin strip of roof flashing (aluminum) which tightened it up just fine.
vanagon40
Greenwood, IN
« Reply #2 on: May 17, 2010, 12:21:54 PM »
Once I was sure I had the pegs where I wanted them, I used a piece of thin walled 1" PVC pipe, with a little Gorilla Glue.  Cut the pipe the length of the bracket and a slit down the side allowed it to snap on over the engine guard.
Steve K (IA)
Cedar Rapids, Iowa
« Reply #3 on: May 17, 2010, 12:44:40 PM »
Leather.  Use a 1-1/8" clamp if your putting it on the curved part of the crash bars.
States I Have Ridden In
« Reply #4 on: May 17, 2010, 12:47:41 PM »
Ditto on the leather.  that's what old belts are for.
blackvalk
PARK CITY, UTAH
« Reply #5 on: May 17, 2010, 01:42:03 PM »
Thanks, I will try one of those suggestions.
elraque
1999 Standard VRCC#31880!
Rock Springs, WY
« Reply #6 on: May 17, 2010, 05:57:52 PM »
Another thing that works surprisingly well is to take an aluminum can and cut a strip of the appropriate width and length. Use the strip as a shim, like the rubber and leather that were suggested. The aluminum can already has a curve to it and will conform nicely to your highway bars.
If you need more "shimmage" cut the strip longer. If you need less "shimmage" cut the strip a little shorter until it fits just right.
This also works if your handlebar clamps get worn and loose for some reason.
Wyoming native
(Endangered Species)
