July 15, 2025, 02:40:49 PM *
Author Topic: replaceing choke cable on interstate  (Read 1395 times)
Hoosiervalk
Bristol, IN
« on: May 17, 2010, 03:00:13 PM »
Hello everyone!...broke my upper choke cable at the switch houseing Sat. is there an easy way to switch it out?
3W-lonerider
Shippensburg Pa
« Reply #1 on: May 17, 2010, 04:31:58 PM »
yep..it isn't that bad really..the upper section joins up with the 2 lower sections behind the neck cover if i recall correctly. split the housing on the handle bars..remove the cable then follow it down to the joint and unhook it there..install new one in reverse order..
Mr.BubblesVRCCDS0008
« Reply #2 on: May 17, 2010, 05:41:40 PM »
Until you get a new one you can operate the choke by pushing the slide on the left side forward with a screwdriver. I had to do this on mine last winter. cable is easy to change.
Hoosiervalk
Bristol, IN
« Reply #3 on: May 18, 2010, 02:47:48 PM »
Hey guys thanks! I got her ordered today...can't wait to tear in there and get it done. do you think I need to put some lube in the houseing? if so what kind? oh yeah do any of the shops have any parts in house???????
DFragn
« Reply #4 on: May 18, 2010, 03:15:01 PM »
If it the Honda OEM replacement no lube is necessary. The OE cables are nylon core.
Hoosiervalk
Bristol, IN
« Reply #5 on: May 18, 2010, 03:33:52 PM »
Thanks DFragn and yes they are oem
