November 21, 2025, 06:44:38 AM *
Author Topic: What kind of Oil Do U guys Use,Is there a Differance  (Read 2994 times)
Maldog
Woodstock IL
« on: May 17, 2010, 03:50:32 PM »
Hay Guys I did just change oil on my i/s I used Honda GN4 20 /50 this time with a half gt. of Lucas Oil Additive <I like Lucas Products alot,any way  do any of u guys use regular oil ie.Penzoil   what ever I use Castrerol in all my other  toys,, what opinion do u gentelmen have on oil product selection,as always thanks fer ur input.. Undecided
« Reply #1 on: May 17, 2010, 04:18:45 PM »
search is your friend, u will find many opinions otherwise known as the oil wars.
I presently use amsoil 10w30/30HD diesel oil.
I would stop using lucas, their products tend to foam and air doesn't lubricate, there are various oil studies out there that show this, including the below site,
see www.bobistheoilguy.com
« Reply #2 on: May 17, 2010, 09:55:15 PM »
Oh boy....and oil thread.   Grin
Mobil motorcycle oil (v-twin) 20/50 with a Purolator Pure One filter (PL14610).  It's longer and alows for 4 full quarts.  If you use an oil filter cover you might want the regular length filter....PL14612)
bg
Cumming, Ga
« Reply #3 on: May 18, 2010, 02:36:25 AM »
shell rotella in the blue bottle, full synthetic
joefromperry
Perry, OH
« Reply #4 on: May 18, 2010, 07:37:57 AM »
Amsoil 10w/40 motorcycle oil in all my bikes with absolutely no complaints. Walmart filters.
2000 Honda Valkyrie Interstate Silver/Blue
2002 Honda Shadow ACE Deluxe
1972 Honda CL350K4 Scrambler
2008 Ural Patrol
1987 Honda Rebel 450
Big Rig
Woolwich NJ
« Reply #5 on: May 18, 2010, 09:15:05 AM »
Olive
for my pasta...and chicken!!!
Om sorry it is lunch time and i am starving!
Farther
Quimper Peninsula, WA
« Reply #6 on: May 18, 2010, 09:31:00 AM »
I have Amsoil 10w40 motorcycle oil right now but will probablly try Shell Rotella 6T next time.  I use a Honda car filter.  Does that count as part dark side?
~Farther
X Ring
VRCC #27389, VRCCDS #204
« Reply #7 on: May 18, 2010, 09:48:57 AM »
Hazman
Thumb of Michigan
« Reply #8 on: May 20, 2010, 04:58:24 PM »
I use Rotella T in the blue jug.  I was just told that I should use motocycle oil due to the way the gears in the transmission may gum up if using automotive type oil. The motocycle  oil is made not to do that. Has anyone else heard that?
Pete
« Reply #9 on: May 20, 2010, 05:00:44 PM »
Kendall 20w50 GT
blackcat
Nicholas Vore VRCC # 30301
Mounds, Arkansas
« Reply #10 on: May 20, 2010, 05:48:16 PM »
since you like lucas, why not use the lucas motorcyle oil
i use the 20w50 fully synthetic(red cap) avalible at orielly,s or advance auto  about 8.75 a quart and no need to add lucas additive
there is also a semi-synthetic (blue cap) i forgot the weight  have used it also but perfer the other
blackcat
« Last Edit: May 20, 2010, 05:53:01 PM by blackcat » Logged
______________________
03 Standard -Fast Black
00 Interstate - Red/Black
97 Tourstate - Yellow/Ivory
2010 Goldwing - Pearl Yellow
John U.
Southern Delaware
« Reply #11 on: May 20, 2010, 05:55:31 PM »
Motorcycle transmissions are rough on oil. The gears will chop the long strand molecules into little bits, which destroys viscosity. Synthetic oils resist the tendancy to lose viscosity. The primary diference between car and motorcycle synthetics is the additive package. Too much moly can mess up a wet clutch, though most oils, including some motorcycle oild have some moly content. Check out Bobistheoilguy.com for much more than you will ever want to know about motor oil.
alph
Eau Claire, WI.
« Reply #12 on: May 20, 2010, 07:00:40 PM »
amsoil 20w 50, sure it's $11 a quart, but it's a valk!
« Reply #13 on: May 20, 2010, 07:17:00 PM »
http://www.amsoil.com/a/wholesale-preferred-customer
CamTom12
VA
« Reply #14 on: May 20, 2010, 07:35:48 PM »
This oil change I tried Delo 15W-40, same as my Diesel. Are there any issues with this that y'all see? It's been running great but I haven't pushed the clutch too hard.
« Reply #15 on: May 21, 2010, 04:44:53 AM »
great oil, however a few yrs ago the formulation was changed and now it contains almost 300 ppm of moly. www.bobistheoilguy.com  oil analysis sections.  Per a SAE report I have posted before problems start showing up with the starter clutch first at 500ppm with problems with the main clutch also at 750ppm.  search my handle the SAE # and a google search will bring up many sites discussing this.
