November 21, 2025, 06:41:58 AM *
Author Topic: Final drive rebuild  (Read 1904 times)
namsgt1946
« on: May 18, 2010, 11:23:50 PM »
Started my rebuild on the final drive on '99 Valk.  But before I go to mother Honda for bearings and seals is there a better ( translates to less expensive ) place to purchase needed items?  Any thots appreaciated!!!!
1FAST6
Sanford, NC
« Reply #1 on: May 19, 2010, 08:11:25 AM »
You might check ebay for a used one.  My buddy replaced his with one that looked like new for around $200.  I think he got it from Pinwall.  Not sure what your parts will cost to rebuild it, but when you subtract cost of parts and divide by hours, you find out what your time is worth...
« Reply #2 on: May 19, 2010, 08:36:22 AM »
There isn't but one seal that you need to replace and the bearings should be good also and not need replacing!
Tx Bohemian
Victoria, Tx
« Reply #3 on: May 19, 2010, 12:59:21 PM »
When I was having trouble with mine and thought I was going to replace all bearings and seals the cost of the parts was $180-190 through HDL (I think) or one of the on line suppliers.  This did not include the gears which what I understand are built like tanks, and they did look good.
I ended up buying one off a member that triked his bike. Paid $225 for it and it was a polished unit.
Al
Dag
Country Rep. Norway
« Reply #4 on: May 19, 2010, 03:18:24 PM »
http://valkyrienorway.com/partsfinaldrive.html
HONDA 91302-MA6-003 O-RING (61X2) All Models
HONDA 91358-MG9-003 O-RING (50.5X3.5) All Models
HONDA 91356-MG9-003 O-RING  (39.5mm x 2.4mm) 3rd elusive All Models
HONDA 42616-MAJ-G20 Thrust Washer All Models
Carolina Bike & Trike VI-1 O-RING KIT (Three O-Rings) All Models
HONDA 91356-MG9-003  O-RING (39.5X2.4) All Models
HONDA 94109-14000 WASHER, DRAIN (14MM) All Models
Direct Line Parts HO-0171876x10 WASHER, DRAIN (14MM) (10-pack) All Models
http://valkyrienorway.com/partsrwheel.html
HONDA 91052-MAE-004  Rear Wheel Bearing LEFT All Models
HONDA 91053-MN5-003 Rear Wheel Bearing RIGHT All Models
HONDA 91253-443-762 DUST SEAL (30X47X8) All Models
